Originally Posted by vince9 I am in the process of converting my garage into a home cinema by using an HD projector. My one question is that the walls in the garage are currently a fresh white colour, Is it essential to have dark coloured walls when using a projector or will I be able to get away with them as they are ? |
Hi vince9
Its not essential to have dark walls IMHO, I did mine a light colour because I wanted to use the room as a den as well as a cinema and dark walls would make it seem a lot smaller and closed in. To get a better overall cinema effect of course a rich dark colour is better. You will get some light reflection on the walls adjacent to the screen so you could consider doing that area a darker colour if you wanted to. But to be honest its not a problem to me and certainly doesn't spoil the viewing experience at all.
I think if I was just going to use it to watch films I would probably go for a dark colour for the effect though.
Terry
