Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 10-12-2006, 6:23 PM   #1 (permalink)
Novice
Hello all,
I'm completely new to this home cinema game and was wondering if any of you could give me some help. I've just bought a new flat and want to plan my setup before I commit to buying anything.
I have some ideas but need to know if I have thought of everything.
I am probably going to buy the Sony KDL40W2000U LCD TV and have it wall mounted in the middle the longest wall in the room, about 1m from the floor. I am planning to have an AV rack with AV amplifier (not decided which), upscaling DVD player (not decided which) and XBox 360 in the corner of the room, and 5.1 speakers dotted about the room.
I have been advised to run the following cables:
TV to AV Rack - 1xSVHS, 2xHDMI, 2xSCART (RGB), 1xethernet, 1xUSB, 1xcomponent, 1xVGA, 1xaudio, 1xco-axial
Ariel output to TV - 1xco-axial
Ariel output to AV rack - 1xco-axial
AV amp to speakers - speaker cable
AV amp to subwoofer - subwoofer cable
I am also going to have 2xoptical audio cables and 3xco-axial audio cables running from my devices to the AV amp.
Does this sound about right?
Also,if its possible, I would like to be able to play my mp3s through the AV amp. Any ideas what the best device to do this with is?
Cheers very much.
greg1903 is offline   Reply With Quote
Old 10-12-2006, 7:22 PM   #2 (permalink)
Woodywizz's Avatar
Thanks: Gave 1,013, Got 1,272
Re: Novice
Sounds about as 'future-proof' as you can be on the cabling front
Now, if you give us a budget and we'll all try to advise you on which kit to get. With regard to the MP3s - connect your MP3 player, via a dock, to the amp - Denon amps are particularly user-friendly in this regard.
Oh, and welcome to the forums
Matt
Panasonic TH42PX70; Onkyo TX-SR606; Mordaunt Short Genies 6.1; SkyHD; PS3 Slim 120GB;
PSN: Woodywizz
Woodywizz is offline   Reply With Quote
Old 10-12-2006, 9:40 PM   #3 (permalink)
Re: Novice
I was planning on doing things in stages and probably look to spend 1k-1.5k, not including the tv. Is this do-able?
novice
