Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Soundproofing help! Tracey Home Cinema DIY 14 01-12-2008 8:56 PM
Soundproofing Help lnewey6 Home Cinema DIY 9 01-11-2005 5:58 PM
Stupid soundproofing \ acoustics question spamboy Room Acoustics, Audio and Video Calibration 14 09-06-2005 3:51 PM
Soundproofing or not? Stellavision Home Cinema DIY 2 26-01-2004 9:59 AM
Soundproofing or Not Soundproofing Jesus Barrera R Home Cinema DIY 2 06-07-2002 12:29 AM
Old 31-08-2006, 12:21 PM   #1 (permalink)
Robbie
Posts: n/a
Another Soundproofing Question
I am currently boarding out my garage with the intention of using it for.... you guessed it a home cinema =)
I have used 50mm batons to make the studwork and high density Rockwool in the cavity. This is topped off with 9mm MDF (just because i had it available) plasterboard on top of this and then it is to be skimmed. all of the joints will be sealed with silicone or something similar on each layer to make it air tight.
I have installed 20mm plastic conduit to bring the speaker wires down from the roof space.
Question 1 what is the best way to seal the conduit when the cables have been installed as I guess the sound will travel up them into the roof void?.
For the sockets I had planned to use plaster board quick fit boxes. are these likely to let too much sound escape and would I be better using standard surface boxes? (Obviously I don’t want them surface if I can help it.)
Has anyone had any experience of this??
Rob
Old 31-08-2006, 11:05 PM   #2 (permalink)
Thanks: Gave 0, Got 21
Re: Another Soundproofing Question
Robbie,
Consider some loose insulation in the conduit. Or seal with some sort of removable caulk.
Ted White
Ted White is offline   Reply With Quote
question, soundproofing
