Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
I think I'm stupid... F1Boy Portable Music (MP3, iPod etc.) 5 23-06-2006 10:15 AM
something stupid THE BOARS AV Amplifiers and Receivers 6 13-05-2006 8:42 AM
Am I Stupid.... TV through my PJ!!! garyhun Projectors 13 03-03-2006 9:44 AM
Plasma, what a stupid stupid technology!!! ggp159 Plasma Televisions 19 27-02-2004 11:36 PM
My stupid, stupid Panny! Sam CRT Televisions 17 24-03-2001 1:03 AM
Old 30-08-2006, 11:27 PM   #1 (permalink)
Thanks: Gave 2, Got 1
Exclamation I'm so STUPID can anybody help??
I've just tried fitting my new panasonic TH-42PX600 to the wall using some
M6 metal Rawlplug wall bolts. I used a 12mm drill bit and made the holes 50mm deep as instructed on the packet. But the holes are too big!!!
The bolts will tighten up so far but when they get too much resistance the whole thing just spins in the hole!!!
Not sure if the drill slipped slightly when I was drilling the holes and as a consequence they are now a bit bigger than they should be or whether its something else. Has anybody else had this problem?
Now the problem is that I dont want to move the postion of the mount and make new holes because it wont look right. Can I fill the holes and redrill? If I use filler will it be strong enough or should I use something else?
Any advice would be greatly appreciated!!
zedologist is offline   Reply With Quote
Old 30-08-2006, 11:49 PM   #2 (permalink)
GasDad's Avatar
Thanks: Gave 185, Got 234
Re: I'm so STUPID can anybody help??
What is your wall made of ? eg block, victorian brick, random stone etc
What sort of drill did you use - eg SDS, cordless, rotary hammer mains drill etc
How hard was it to drill - 10 seconds a hole .... .1 hour a hole
I take it it said to use a 12mm drill on the packet
You can probably glue them into their holes - but what the hole is in is important.
James
Sky HD, Yamaha 757SE, Pioneer 436XDE, Quad Lites
GasDad is online now   Reply With Quote
Old 31-08-2006, 1:01 AM   #3 (permalink)
Thanks: Gave 218, Got 560
you could allways get some M8 bolts and use them.
make hole slightly larger to suit the size of the M8 bolts...
Cheers Stuart.
My Full Kit List | If we have traded, leave me feedback and il leave you yours.
Whats The Point Of Having A Trade Rating, When Some Members Cant Be Bothered To Use It !
You Know The Trading Forums Are A Dangerous Place To Read..Costs A Fortune
T0rNaDo is offline   Reply With Quote
Old 31-08-2006, 7:08 AM   #4 (permalink)
Thanks for the replies guys the wall is breese blockcovered in plaster board. It took less than a min to do a hole usinging a mates boschammer cordless SDS drill. Thought about using bigger bolts but they won;t go through the eye holes on theis panasonic mount.
Old 31-08-2006, 7:09 AM   #5 (permalink)
Thanks: Gave 1, Got 1
If moving up a size to M8 doesn't work, you could always use a chemical anchor system where the threaded rod is set in the hole with a very strong/tough glue. These can be a bit more expensive that expansion bolts, but if you're struggling it might be an idea.
Screwfix do quite a few options here.
Hope this helps
Si
Won't you gentlemen have a Pepsi?
Rommel is offline   Reply With Quote
Old 31-08-2006, 7:25 AM   #6 (permalink)
GrahamC's Avatar
Thanks: Gave 8, Got 48
Here's an idea ... No Nails in the hole or on the body of the bolt. Never tried it so ...
Panasonic px80 37" Plasma, Humax PVR, Sony s350 BluRay, Marantz 7300 AV receiver, Boston Micro centre and sats with Rel sub.
Homepage: The virtual presence of GrahamC
GrahamC is offline   Reply With Quote
Old 31-08-2006, 9:26 AM   #7 (permalink)
GasDad's Avatar
Personally that's what I'd do - but then I think people make too much fuss about the weight of their plasmas - My pio 436 bracket is screwed with four screws to a 2x4" temporary frame (sorry height evalutation device ) at the moment.
James
Old 31-08-2006, 10:11 AM   #8 (permalink)
hi mate
dont use the hammer action into the breeze block, look at screwfix online they have loads of fixing solutions ,
good luck
johnone is offline   Reply With Quote
Old 31-08-2006, 10:31 AM   #9 (permalink)
Thanks: Gave 1, Got 9
A lot of people use gripfill
http://www.screwfix.com/app/sfd/cat/...39235&ts=20221
dobbin is offline   Reply With Quote
Old 31-08-2006, 11:29 AM   #10 (permalink)
Polyurethane adhesives are very strong, see here.
It's currently holding up the curtain poles in my living room...
Old 31-08-2006, 6:32 PM   #11 (permalink)
Thanks: Gave 0, Got 11
If you are using raw bolts...then you have an expanding sleeve, and inside is a threaded stud...on teh end is a nut.
Have you tried holding the stud still, with mole grips or similar, while doing teh nut up?
This will allow the expanding section to grip into teh breeze, before you finally do it all up.
Also...dont forget....that i fyou are trying to do it up with teh bracket in situ...you dont need to...you can tighten then enough to lock in, then remove teh nuts, fit teh bracket and re-fit teh nuts.
If you do need to go up a size...just drill out teh mounting holes in teh bracket.
If when done, its lopsided...elongat teh holes, so you can wiggle it around with a spirit level on top, tehn tighten it up.
Yes, I know its "the" not "teh"...tell my fingers that!
Skeet is offline   Reply With Quote
Old 31-08-2006, 6:34 PM   #12 (permalink)
thanks for the replies. I called the technical line at Rawlplug and they said that an epoxy resin was the best choice with some 6mm threaded rob cut to size. So its all up on the wall now, just got to wait for it to set!!!! one hour and counting!!
Old 31-08-2006, 6:59 PM   #13 (permalink)
When you say its all up on teh wall now...i assume you mean teh studs..or studs and bracket? Not the TV!!
Sounds good mate...what epoxy did you use?
stupid
