Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
wall mounting a 32" lcd... oasisnut Flat Screen TV Brackets and Mounts 6 22-06-2006 3:44 PM
Wall mounting a 40" LCD andru Flat Screen TV Brackets and Mounts 6 29-04-2006 2:42 PM
Wall mounting 32" LCD to plasterboard mr1000 Flat Screen TV Brackets and Mounts 8 03-01-2006 2:45 PM
Mounting 32" LCD TV on chimney breast? tomto Flat Screen TV Brackets and Mounts 3 14-02-2005 8:49 PM
Small LCD TV 14-17" plus mounting options. NewBeetle Flat Screen TV Brackets and Mounts 15 11-06-2004 9:42 PM
Old 27-08-2006, 6:31 PM   #1 (permalink)
Newbie mounting 40" LCD!!!
Please could someone offer some advice for mounting my Samsung 40" LCD. I have purchased a wall bracket already. see below
http://cgi.ebay.co.uk/UNIVERSAL-PLAS...QQcmdZViewItem,
but am unsure as to the best way of securing it to the wall which i beleive to be solid (1900ish tenament). Am i best to secure some wood to the wall and then attach the bracket to the wood or go straight to the wall? I want it to be secure as possible and have no worries about it crashing down
What should i use to secure either the TV or wood to wall, large screws and raw plugs or anchour bolts?
I have noticed most other wall brackets are slightly different from the design i have is there any difference?
Any help much appreciated
Sadam13 is offline   Reply With Quote
Old 27-08-2006, 7:20 PM   #2 (permalink)
Thanks: Gave 0, Got 11
Re: Newbie mounting 40" LCD!!!
Solid wall is the best bet...LCD's are comparativly lighter than Plasmas so you should be ok...look at teh mounting holes and choose a bolt to fit, or if not just enlarge teh holes...if you elongate teh holes slightly, taht will help final adjustments if for some reason its ******ed.
Fisher make expanding wall studs, and once they are in...you would need a JCB to pull them out of teh wall mate...I think people are recommending 100mm by 10mm ones...
Drill teh hole to teh correct depth, so that enough of teh stud protrudes, but remember, that when you tighten them up...the stud will come out further as it drags up teh expanding part.
Yes, I know its "the" not "teh"...tell my fingers that!
Skeet is offline   Reply With Quote
Old 27-08-2006, 7:23 PM   #3 (permalink)
Thanks Skeet
Old 02-09-2006, 3:49 PM   #4 (permalink)
Thanks: Gave 29, Got 7
Hi Sadam13
Have a look here
My Setup Now!!!!!!!!!!!!
Read through the thread Plasma mounted on plasterboard no fixings
in studs! Need any help PM me i sell fixings for a living.
Rab.
RABG is offline   Reply With Quote
lcd, newbie mounting 40
