Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 20-08-2006, 9:48 PM   #1 (permalink)
Plasterboard Ceiling : Interset or Spring Toggle?
Hi folks,
after a few searches, I can see this is a popular topic (perhaps a Board Admin could sticky a good thread?), but my question is quite specific.
I have a stud detector (mind of it's own), have traced taping/nailing lines and rapped my knuckles raw on the ceiling, but I'm still unsure that I can easily identify joists (and where I can - they're in the wrong place!), so I going to take the plunge with plasterboard fixings.
I've used the interset ones on walls many times, but I am wondering if the toggle bolts are better as the the load is a "pull" rather than "shear"? I also came across a fixing I've never seen before.....
Interset : http://www.screwfix.com/app/sfd/cat/...09851&id=11143
Toggle : http://www.fwb.co.uk/mall/productpag...WBGroup/436NNH
New to Me : http://www.screwfix.com/app/sfd/cat/...09851&id=36664
Worth mentioning : I cannot get access to the ceiling above; mounting plate doesn't help (if I knew where the joists were...... ;-) ; the celing is 2.3m wide; PJ is an Opt HD72i 3.1 Kg (4 screw mount) and Screen a Grey Wolf 2 9Kg (2 hook fixings)
Many thanks,
Heeb
Heebson is offline   Reply With Quote
Old 20-08-2006, 10:12 PM   #2 (permalink)
Thanks: Gave 1, Got 4
why not bite the bullit and make a small hole in the ceiling, enough to get a small light source into, then you can see the centres the timbers at.
or use a small punch and do a series of holes until you find timber, you can easily fill and paint the affected area.
better to fill a ceiling hole rather than have you pj on the floor
thomo99 is offline   Reply With Quote
Old 21-08-2006, 12:08 AM   #3 (permalink)
Thanks: Gave 7, Got 15
For the projector use toggles - anything else may pull/slide out easier. I'm not sure if these would be OK for the 9kg screen though.
But I would be inclined to make a small hole to find the joists, and fit a mounting plate ot timber board - which will then cover the hole
woody67 is offline   Reply With Quote
Old 19-09-2006, 10:21 PM   #4 (permalink)
Thanks: Gave 1, Got 0
Re: Plasterboard Ceiling : Interset or Spring Toggle?
Get yourself a drill with a very fine bit and drill around till you feel resistance going in. Drill around a bit more to mark out the width of the joist. The holes will fill easily enough.
Personally I wouldn't use a plasterboard fixing, in fact I think that's quite scary. If the joist falls in the wrong place span 2 joists with a square of MDF or hardboard and secure into that.
mrscalex is offline   Reply With Quote
Old 26-09-2006, 12:32 PM   #5 (permalink)
Thanks: Gave 4, Got 2
I've used toggles on my screen, but the ceiling is lathe and plaster as opposed to plasterboard so the toggles are gripping the nailed on lathes.
I would recommend going the 'testing' route with a very small drill, or bradawl. Worst case is that tou'll end up with a few tiny holes in your ceiling that are easily fillable.
rooo is offline   Reply With Quote
Old 26-09-2006, 2:54 PM   #6 (permalink)
IronGiant's Avatar
Thanks: Gave 583, Got 1,555
Another vote for the fine drill, particularly if you think you might have found a joist with your detector. That's what I did for my screen.
Edit: to answer your question, I'd go for a toggle.
Dave
IronGiant is offline   Reply With Quote
ceiling, interset, plasterboard, spring, toggle
