Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Zombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray Review
Clash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD ReviewMulan Blu-ray Review
Old 20-08-2006, 9:27 PM   #1 (permalink)
Thanks: Gave 0, Got 11
Hanging Plasma on 3 layer Plasterboard wall?
Hi.
I have seen the advice regarding single layer stud walls etc...but I have a wall that would be ideal for my new plasma when I buy it, but is made of 3 sheets of plasterboard, stuck together.
What could I use to fix to this?
I have thought of just building a false wall in front of it...or just using a different wall, but this one would suit my current surround setup better.
Any suggestions?
Skeet is offline   Reply With Quote
Old 21-08-2006, 7:37 AM   #2 (permalink)
Super Moderator
Thanks: Gave 612, Got 1,102
Moving to DIY
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
Old 21-08-2006, 8:11 AM   #3 (permalink)
GasDad's Avatar
Thanks: Gave 433, Got 370
Originally Posted by Skeet
Hi.
Any suggestions?
Can you clarify that - are the sheets of platerboard attached to anything?
My Kitchen Thread, Pimp My Sleigh Of course in comparison to PP, I'm a genius at maths, but then so is my goldfish.
GasDad is offline   Reply With Quote
Old 21-08-2006, 10:57 PM   #4 (permalink)
Hmmm...well...pretty sure they are atached to timber frame around the outside...wall also has a door frame in it and a rad on each side.
Its pretty sound, but...plasterboard construction...its not hollow, so teh expanding type fittings, would not work I fear.
Old 22-08-2006, 9:34 AM   #5 (permalink)
GasDad's Avatar
If its got a doorway in it, how thick is this wall ?
James
Old 22-08-2006, 5:15 PM   #6 (permalink)
I would say around 3 inches...
Old 22-08-2006, 8:17 PM   #7 (permalink)
Thanks: Gave 7, Got 15
If there is a void behind the plasterboard, then use a toggle - on a longer bolt if necessary.
But an expansive type plug should grip well enough in 3 layers
woody67 is offline   Reply With Quote
Old 23-08-2006, 9:31 AM   #8 (permalink)
GasDad's Avatar
In that case you definetly have some kind of studding.
To clarify your original post - when you say "three sheets of plaster board stuck together" - do you really mean three sheets of plaster board side by side?
Old 23-08-2006, 9:38 AM   #9 (permalink)
Thanks: Gave 0, Got 3
If it is a stud wall, and as someone has previously stated at 3" width it probably is.
Get a piece of wood the same size as your bracket and cut out the same size of plasterboard.
fix wood to now exposed studs
fit bracket to wood
Sparkypups is offline   Reply With Quote
Old 23-08-2006, 8:19 PM   #10 (permalink)
NO...I really, really mean 3 sheets of plaster board stuck together...I know this from when a) My kitchen was installed and b) when I moved a lights switch in said wall!!
Grim I know....
Old 24-08-2006, 8:06 AM   #11 (permalink)
GasDad's Avatar
Grim I know....
So you've got three layers of plaster board and then what ??? Plasterboard is 1/2 inch thick - given your wall is 3" thick, there must be something else.
James
Old 24-08-2006, 5:42 PM   #12 (permalink)
The plaster board in my house...is about 3/4 inch thick...its is on the dot and dab walls anyway.
I know what I am saying sounds weird...but..as far as I can tell...thats the way it is! LOL! I will have to lay my hands on a stud detector and see what I can find, if anything.
Thing is...if they are as I believe them to be...then do I have any options?
I had thought about bolting right through teh wall, with battons on either side...then placing a suitable picture or canvas or mirror on teh wall teh other side...
Old 25-08-2006, 9:25 AM   #13 (permalink)
GasDad's Avatar
Re: Hanging Plasma on 3 layer Plasterboard wall?
I suggest you measure the thickness of the wall exactly - the must (or should be) some kind of battening.
You say the plasterboard is thicker than 1/2 inch in other parts of your house - does it have attached insulation.
Presumably the radiators are attached to something ?
Failing all else - make a hole in it of sufficient size to have a look to see what (if anything) is inside.
James
Old 25-08-2006, 5:16 PM   #14 (permalink)
Going to acquire a stud detector and have a search around...cheers for your patience though!
Old 25-08-2006, 8:55 PM   #15 (permalink)
Thanks: Gave 32, Got 22
Sounds a bit like upstairs in our house which really confused me to start with. It is stud walls but in between the battening there is an extra layer of plasterboard don't know if it's for insulation/sound proofing. But when you drill through it feels as though your going straight through to the other side as there's no air gap. Hope that helps!!
smiffy333 is offline   Reply With Quote
hanging, layer, plasma, plasterboard, wall
Copyright © 2000-2010 M2N E. & O. E.
