Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Sherlock Holmes Blu-ray ReviewClash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray Review
Cirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray Review
Old 16-08-2006, 10:30 AM   #1 (permalink)
Soundproofing advice
I am in the process of setting up an upstairs room that will act a both an office and an occasional home cinema room (I am not a huge movie watcher so do not plan a massively powerfull system, just somthing where I can crank the volume up a bit and enjoy the experience from time to time)
Here is the problem - one of the walls is a shared wall and I am keen to minimise any noise disturbance to my neighbours. The shared wall is two walls of 4" bricks with a small air gap between them (the house is a 1920/30s semi if this helps!).
I have read the AV forums on soundproofing rooms and have an idea of what to do but am limited slightly in that one of the doors to the room has its frame directly joined to the shared wall and at best can only be moved forward such as to give a depth for the false wall of 3" or 4" (absoloute maximum).
To this end I am thinking of building a frame seperated from the shared wall by an air gap, using Wicks insulation material and covering it with SoundBloc board. My build plan is:
+ Gap between frame and wall 0.5" (this gap works well for positioning the top of the frame)
+ Wood for frame 2"x3" (the depth will be 2")
+ SoundBloc (one or two layers)* skimmed with plaster
* Would one surfice or would I be better going with two?
Does this plan seem reasonable and be likely to keep the neighbours happy!
Many thanks
James
eezjib is offline   Reply With Quote
Old 16-08-2006, 4:22 PM   #2 (permalink)
anfieldfc
Posts: n/a
hi your idea is fine use 2 layers of soundbloc .have you heard of green glue its the new stuff on the block which stop the bass travel better than anything else on the market just remeber that you will still get some going through the floor and celing just try and put you subwoofer on a slab to calm the vibrations down on the floor hope this helps
Old 16-08-2006, 6:20 PM   #3 (permalink)
Many thanks for checking out my spec and for the advice - DIY here I come :-)
James
Old 18-08-2006, 9:43 AM   #4 (permalink)
Thanks: Gave 22, Got 91
I investigated the use of Soundbloc but after reading the papers on the Green Glue Company site I choose 2 layers of 12.5mm standard plasterbaord.
http://www.greengluecompany.com/gree...Soundboard.php
Londondecca is offline   Reply With Quote
advice, soundproofing
Copyright © 2000-2010 M2N E. & O. E.
