The total cost was about £100 which includes all materials of Ply Wood, Chip Board (for the rail) Leatherette for the Rail, WSOP Grey playing surface, Bolts and T Bolts, and Foam. I also has to buy sanding pads, spray adhesive, no nails, clamps, jigsaw blades, and staples.
I already had or borrowed the tools so didnt need to acquire those.
The foam on the playing surface is 10mm soft foam and feels very nice, the grey cloth is also great, the cards glide along and it looks and feels really nice. Its also nice to lean on the rails when having a game of poker.
The foam for the rails is a recycled foam, i would have gone with the normal hard foam and had more of a rounded feel had i made a complete table but as it was sitting on the dining room table i needed the squarer shape due to the shape of the dining room table. I also had to drop the inner track due to the size of my dining room table, (approx 4ft by 5.5ft, as opposed to 4ft by 8ft of a poker table)
The hardest part is the rail and if i was to do it again i would still make the rail but would probably pull the inner side of the foam down with the fabric as opposed to glueing all the foam first.
Has it helped my poker skills, well the first game on it was two weeks ago and i didnt win so no
