| How to wire diplexed wall plates 4 loftbox?
I have just switched on my loftbox.
Picture seems poor slight snow, no text on bbc1 and itv, freeview poor on certain channels through the loftbox. Aerial alone is fine strong signal.
I have used a very high grade sat coax.
I am concerned about the global diplex sockets in the rooms. Do I connect the screen. The entire piece looks metal, I can not see any screening to stop the middle wire conducting with the coax screen through the die cast housing.
Do you connect the inner wire and the screen, i assumed the screen is clamped by the screw with flat piece of metal, and the middle wire in the hole with screw,
If I disconnect the screen the signal seems a lot clearer.
The entire piece looks die cast and looks as if the 2 wires will short if both connected.
