I looked at these ages ago, and they quoted me $145 to ship 2 of them to the UK.
Expensive, but still works out much much cheaper than the Swish tracks you can buy over here.
Did u go for them? Personally, I think I might be shelving the idea for a while and saving up for an HD-DVD player instead. Nevertheless I plan to motorise the curtains next year some time.
Hi, no I didn't in the end, but I still will be needing something at some stage.
The one that Ricky has linked to might be worth a go though, I'll have to have a think about it.
When you change your mind you may have a look athttp://www.letsautomate.com/Swishautoremote.cfm?
I got mine from them about 3 years ago for 330 pounds
Regards
OK I bought one of these that Ricky pointed out. Just got it today, first impressions are that it is well built and should work perfectly for my screen masking system. I'll post more detail when its time to install it properly in my cinema room thread
