| 12 volt Remote control unit required
Help wanted.
I am having some bespoke furniture made, which will come equipped with four 12 volt down lighters.
Having spoken to the surveyor, he will specify the appropriate 12 volt dimmable transformers required, that can be dimmed. However, I will have to specify my own remote control switch panel.
Can anyone recommend one that I should consider?
Since I am having a left hand side and a right hand side, it may be good to be able to control both separately, but not essential. If I but the unit before it’s installed, they would probably fit it for me.
Any help, links suggestions etc would be most welcome.
Additioanlly, the room in question has two sets of three way lights in the ceiling controlled by a two gang light switch, currently with low energy light bulbs. Is there a unit that Ican use to repalce to control these lights as well?
Adrian
__________________ Fuji P50XHA58EB JVC HD1 Denon AVC-A11XV Arcam DV139 Oppo BD83 MA GR60s & Centre SR Rears V+ My Setup
