Not sure if this is the right forum - apologies if not.
My setup is that I have all my AV kit in a large walk-in cupboard in the hall, feeding through to my TV and speakers in the living room.
It's all set-up pretty well, with the exception of the phone cables going into the cupboard.
I currently have a single phone line going in, but I actually need 3 devices to have a phone connection:
Sky HD box
TiVo box
Normal sky box (for multiroom, used to feed TiVo)
I've not bothered connecting my sky boxes until now, but since the HD installation, I'll need to do so when I get the other one connected up for multi-room.
Obviously, I could put filters onto my phone socket in the hall, and run 3 cables from there into the cupboard. This is messy, and a bit of a pain.
I already have one telephone cable going into the cupboard, is there any kind of "junction box" I can use to allow all 3 devices to share this cable? I have found this one at Maplin, but have no idea if it'll do what I need:
http://www.maplin.co.uk/Module.aspx?...ories&doy=18m7
Any suggestions will be gratefully received - if I can cut down on the amount of cable I need to run across rooms then I'll be delighted!
