27-05-2006, 11:13 PM
#1 (permalink)
I want to change the outer frame color of my plasma
Sorry if this has been asked before. But missus thinks that our old Panasonic plasma silver is a bit passe, so we want to change the frame colour.
Obviously i could get a new frame from Panasonic at a cost of many hundreds but is there a cheaper alternative?
28-05-2006, 7:43 AM
#2 (permalink)
Thanks: Gave 32, Got 166
If you can remove the frame, you could just respray it. Three cans of acrylic car paint from Halfords - one primer, one colour, and one clear laquer - will do the job for about 15 quid.
Panasonic TH-46PZ81B, Arcam AVR350, Linn LK100, Naim NAP110, Quad L-ites, PS3, Samsung 850, Sky+, Humax 9200T, Panasonic E50, Harmony 1000, Pixel Magic HD-MB200, M-Audio Flying Cow DAC, Pronto TSU9600, Mac Mini, iMac
28-05-2006, 7:43 AM
#3 (permalink)
Thanks: Gave 206, Got 140
I seem to remember a while ago in the plasma forum, that someone got their
frame professionally sprayed. If I remember, it was around £200.
Try asking in the plasma forum mate.
::Pioneer PDP 50MXE1::Lumagen VisionPro HDP::Denon AVR 3805::Arcam Diva DV79::Sky+HD::Microsoft XBOX 360::Acoustic Energy AELITE Three's, One's, Centre and Subwoofer::
28-05-2006, 10:01 AM
#4 (permalink)
Thanks: Gave 62, Got 215
IIRC Unicol offer this as a service, give em a shout and ask about it - getting it to them and back might be the expensive bit though - they are in Oxford(although not too bad if you have the original packaging)
That said, I haven't seen the results yet but Zap have resprayed one of ours for us - http://www.zap.uki.net/
Relysis 40 inch LCD, Harman Kardon AVR 630, MCPC (CM260, IMON, Tosh HDDVD-ROM, E2200@2.75GHz, 2400XT, 2GB, 320GB, Sweetspot SDI card,Happauge HVR4000, MCE'05), Kef XQ5/XQ2C/Q2DS/Q8S, Cyrus aca7.5, PSXR, CD6, Quad 303 x 3, Sky+ 250 SDI
28-05-2006, 11:59 AM
#5 (permalink)
Thanks: Gave 49, Got 24
I painted a silver lcd monitor surround black a couple of years ago. A couple of thin coats of primer, then 4 thin coats of black - looked great. Definitely spray thin coats to avoid running. It was only a 15" screen but should just be more of the same.
My kit: Denon AVR 1906, Infocus Screenplay 4805, Toshiba SD 350 DVD, Sony VTX-800 Freeview box, Dell Optiplex PC, Wharfedale 9HCP speakers. Visit my site to see details of the cinema
Rogues are preferable to imbeciles because they sometimes take a rest. - Alexandre Dumas
29-05-2006, 5:37 PM
#6 (permalink)
Thanks: Gave 0, Got 6
You could maybe mask the screen and paint without removing the panel maybe or have you thought about vinly, you can get all sorts of colours and designs. And if you don't like it peel it of and try a different colour.
29-05-2006, 5:49 PM
#7 (permalink)
Assured Advertiser
Thanks: Gave 76, Got 1,097
what screen? PWD/PHD or a veira?
