AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 18-05-2006, 1:17 PM   #1 (permalink)
AgentCool's Avatar
Thanks: Gave 48, Got 84
Panasonic TX-26LXD500 on Plasterboard Wall
I'm thinking of putting my Panasonic 26LXD500 on the wall but not sure if the wall itself will be able to take it. The wall is of the plasterboard variety, probably less than an inch thick supported by wooden studs. I'm not entirely certain if there is a stud where I want the TV though and even so it's a pretty heavy TV for its size, 24kgs with the desktop stand (not sure how much without).
I was thinking of a wall mount I've seen on eBay which features a wall mount attached to a VESA mount which is then attached to a Panasonic adaptor. Does anybody know how many holes you can into the wall with a mount like this. Obviously, I'm thinking the more there are the stronger it will be.
I don't want to mess around with complicated things like wood on the wall etc. I can easily get hold of some wall anchors and have a lot of shelving on the wall already but the weight is spread about more.
Thoughts?
Panasonic TX-26LXD500 LCD TV; Toshiba HD-XE1 HD DVD Player; Sony BDP-S350 Blu-ray Player; Denon AVR-1909 AV Receiver; Wharfedale Diamond 9.0 HCP 5.1 Speakers; Sky+; Xbox 360 20GB; Wii; PS3 60GB; PSP; iPod Touch 16GB; Pure Evoke Flow DAB/FM/Wi-Fi Radio; Nokia N95; Dell XPS M1530
AgentCool is offline
Old 18-05-2006, 2:02 PM   #2 (permalink)
sbowler's Avatar
Thanks: Gave 119, Got 430
Go the wall anchors route.
My flickr Pentax K10D Sigma 10-20/24-135/70-210/Pentax 50mm f1.4/Sigma 24-70mm DG-EX
MyA/V
"Chance favors the prepared mind"
sbowler is online now
Old 18-05-2006, 4:44 PM   #3 (permalink)
Johnny Thunder's Avatar
Thanks: Gave 206, Got 140
You could always cut out the plasterboard behind the display, and fit studs
exactly where you want them, put the plasterboard back in, touch up nicely
and you have solid fixings.
::Pioneer PDP 50MXE1::Lumagen VisionPro HDP::Denon AVR 3805::Arcam Diva DV79::Sky+HD::Microsoft XBOX 360::Acoustic Energy AELITE Three's, One's, Centre and Subwoofer::
Johnny Thunder is offline
Old 08-06-2006, 8:36 PM   #4 (permalink)
Thanks: Gave 4, Got 24
johny....you mean just screw timber to the brick?
btw I hung a 26" sammy lcd with the bracket tesco do (£9.99 in the sal). Used heavy duty anchors x 6 and its sound....for now..
diggler46 is offline
panasonic, plasterboard, tx26lxd500, wall
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
