18-05-2006, 11:45 AM
#1 (permalink)
Thanks: Gave 1, Got 0
Where can I buy Chrome Poles?
Afternoon, I've mounted my screen on the wall and want to put 2 x chrome bars on the wall so that it looks like its on a stand and will conceal alll the cables. Anyone any idea where I can buy some chrome poles from, I've tried BandQ and could only find 1" diameter piping, also tried unicol but they are 0.35 per cm which seems a bit steep. Help please??
18-05-2006, 11:48 AM
#2 (permalink)
Thanks: Gave 6, Got 2
Wickes do thick chrome poles, used for supporting breakfast bars. May not be long enough for you but worth a shot.
18-05-2006, 12:02 PM
#3 (permalink)
Thanks: Gave 5, Got 8
Chrome Poles
I had exactly the same idea last weekend, got ruled out by my SO. I found chrome poles of various lengths (up to 2M) and diameters in Homebase. They even had a plastic coating to keep the finish while installing, It looked like it would peel off easily.
Go For it.. wish I had..
27-05-2006, 10:24 AM
#4 (permalink)
Thanks: Gave 62, Got 215
Btech do thicker ones iirc. Nothing beats unicol, but as you aren't actually hanging a plasma from it, you are forgiven!!
Relysis 40 inch LCD, Harman Kardon AVR 630, MCPC (CM260, IMON, Tosh HDDVD-ROM, E2200@2.75GHz, 2400XT, 2GB, 320GB, Sweetspot SDI card,Happauge HVR4000, MCE'05), Kef XQ5/XQ2C/Q2DS/Q8S, Cyrus aca7.5, PSXR, CD6, Quad 303 x 3, Sky+ 250 SDI
28-05-2006, 5:15 AM
#5 (permalink)
I gave my neighbour a hand mounting his plasma yesterday and he had purchased an extruded aluminium 'pole' to conceal the wires. It was from Vogel a EFA 6835 cost about £35 and seemed to work really well. You can also get some optional shelves for mounting AV equipement on as well. I quick google revealed this
http://www.microdirect.co.uk/Product...6&GroupID=1436
Steve
01-06-2006, 10:56 PM
#6 (permalink)
Thanks: Gave 2, Got 1
Re Chrome Poles
I am sure Mr. Stringfellow can help you out on this one. He may even have some 'Second User' or 'Ex-demo' ones lying aroung, may just require a quick wipe down with Dettox !!
