15-05-2006, 3:08 PM
#1 (permalink)
Thanks: Gave 3, Got 3
ceiling height
hi does any body no the hight limit for a ceiling in the living room
15-05-2006, 3:20 PM
#2 (permalink)
Thanks: Gave 36, Got 12
depends what type of building it is really, i live in a victorian house and my ceilings are 12ft high, some new builds might be 10ft, some slightly less, some higher.
could you be a bit more specific, i.e. what would you be looking to install and at what height? or are you looking for the general dimensions of most people's home cinema rooms?
15-05-2006, 4:54 PM
#3 (permalink)
ceiling height
hi i want to build a suppended celing my height now is only 7 foot 8inchs and i cant seem to find any regs in any book
15-05-2006, 5:49 PM
#4 (permalink)
Thanks: Gave 4, Got 8
Legal is 2 meters head clearance I know just had my loft conversion completed and had a load of trouble with the building control people over head room they stipulated that I must maintain 2 meters...
15-05-2006, 5:54 PM
#5 (permalink)
Thanks: Gave 24, Got 14
Are you sure? I don't think I have 2 metres head room in any room in our house.
A minimum head clearence is going to depend very much on whos head the clearence is measured from.
15-05-2006, 6:38 PM
#6 (permalink)
Thanks: Gave 32, Got 166
My living room and kitchen have a clearance of 6 feet 5 inches. It's an old cottage with a beamed ceiling. Previous owners had the floor lowered several inches, so originally it would have been just over 6 feet.
People were a lot shorter 200 years ago.
Panasonic TH-46PZ81B, Arcam AVR350, Linn LK100, Naim NAP110, Quad L-ites, PS3, Samsung 850, Sky+, Humax 9200T, Panasonic E50, Harmony 1000, Pixel Magic HD-MB200, M-Audio Flying Cow DAC, Pronto TSU9600, Mac Mini, iMac
15-05-2006, 7:51 PM
#7 (permalink)
Thanks: Gave 1, Got 2
You can make the room as low as you like - but remember you need to be able to open a door to get into the room and usually this is 1987mm high.
The 2000mm rule is for stairs leading to loft conversions only, (this can actually go down to 1900mm at a push with your building control officer).
Fight Club..Tyler Durden: The things you own end up owning you
15-05-2006, 8:02 PM
#8 (permalink)
Thanks: Gave 7, Got 15
There is no longer any limit for ceiling height under the building regs, it really comes down to practicalities. The only minimum is 2m for stairs and landings.
As already posted, the minimum practical height would perhaps be the same as a typical modern door frame - 1.981m
15-05-2006, 8:25 PM
#9 (permalink)
This if for new build remeber not a building already made ... Honest it is 2 meter minimun, my building control in essex made me make alteratiosn to a staircase i had especially made all over 25mm
15-05-2006, 8:51 PM
#10 (permalink)
Staircases are special as it is easy to bang your head and fall down the flight, especially if running down to escape a fire or such like. The dimension is specified in the approved documents and other texts, and its difficult to prove that anything less than 2m is safe for a staircase. Rooms are different.
