AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 15-05-2006, 1:44 PM   #1 (permalink)
Rockwool Question
Hi all
Quick question from a real amateur!
Is this the right Rockwool stuff to help with soundproofing:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
Thanks in advance for your help!!
TimPOwen is offline
Old 15-05-2006, 1:53 PM   #2 (permalink)
Thanks: Gave 110, Got 108
are you wanting to put it in the walls or make acoustic panels with it
mattym is offline
Old 15-05-2006, 2:06 PM   #3 (permalink)
Put it in the walls.
TimPOwen is offline
Old 15-05-2006, 2:19 PM   #4 (permalink)
should be fine if you can get slab, though as long as its dense it will be fine
mattym is offline
Old 17-05-2006, 8:24 AM   #5 (permalink)
Thanks: Gave 57, Got 56
Rockwool = horrible, itchy stuff!
We've put rather a lot of it into our new house, internal walls are filled with 80mm, 200mm between the ground and first floor, 300mm between the first and second floor, 80mm in all the external walls over 75mm Kingspan....
baldrick is offline
question, rockwool
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
