AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 11-05-2006, 12:33 PM   #1 (permalink)
Thanks: Gave 9, Got 4
Cinema Room Size advice
Guys, hope you offer the benefit of your advice/experience.
I'm currently thinking of converting one of my bedrooms into a cinema room. The only problem is, it's not very big, and I don't know if the room would be suitable. The room itself only measures approx 305cmx285cm. Due to positioning of a window, I'm going to have to use the shortest distance of the room as the viewing distance (ie the wall behind me will be 285cm from the wall holding the screen in front). Otherwise I'd have the window behind me.
Do you reckon this is to small to bother with? Having used some of the screen calculators online, it's really difficult finding a screen small enough! It's still in the early planning stages, so I don't know what kit I'd be looking at just yet, which I know restricts things a little!
Dave
dave_turk is offline
Old 11-05-2006, 12:46 PM   #2 (permalink)
Thanks: Gave 3, Got 3
i think the room will be fine. my size room is 330cm long 250cm wide and its fine my tv is a 42inch plasma and a 6 foot screen and its great enjoy it its great fun try and take some pics of your room when its done
anfieldfc is offline
Old 11-05-2006, 3:37 PM   #3 (permalink)
Thanks: Gave 1, Got 6
Do it size doesn't matter take a look at mine its a bit smaller than your rooom 10' x 9'1" (3.05m x 2.77m) works great. I had the same problem with the projector but went for a Themescene H30a and a 5' screen works great.
Good luck
See my setup at http://www.avforums.com/forums/members-home-cinema-gallery/281377-smallest-dedicated-ht.html
OBee1 is offline
Old 11-05-2006, 4:06 PM   #4 (permalink)
surrey lad's Avatar
Thanks: Gave 6, Got 12
It's not the size that matters but the quality of your equipment
Kit; VDC Marquee-HD145-Vidikron case, Crystalio II, 8ft Stewart 130, TViX 6500a, HTPC, Roksan TT, TiVo, Lex MC8v2, Sunfire Cinema Grand Sig amp, Totem Mani-II Ref fronts, rears & centre, Paradigm Servo-15/BFD/REW, Sony ES DAB, Pronto.
To find me on the map click here CRT
surrey lad is offline
Old 12-05-2006, 8:55 AM   #5 (permalink)
Thanks: Gave 4, Got 8
The room size is no problem, my home cinema is in a room 2.76m x 2.46m and with a screen width just under 2m is fine.
Visit my home cinema's the Singleplex and Microplex here:- http://www.singleplex.co.uk
Alan Westy is offline
Old 12-05-2006, 10:07 AM   #6 (permalink)
Thanks for the replies so far guys . I'm guessing then that the main thing that'll affect the screen size is the projector. I was looking at the Optoma HD72i, but according to the calculators I've seen, with a throw distance of approx 2.5m I should get a screen of less than 1.5m width, do you guys use the zoom function on the projector to increase the picture size? Does this give any degredation?
Dave
Old 12-05-2006, 11:59 AM   #7 (permalink)
inzaman's Avatar
Thanks: Gave 60, Got 232
The zoom function can be used to adjust the picture size, see a projector calculator here http://www.projectorcentral.com/proj...ulator-pro.cfm to get settings of the various pj's. I dont know if the H72 is on there though.
The zoom function should not give any picture degredation, i have my H78 pretty much fully zoomed and notice no degredation in quality.
Visit my Home Cinema here
inzaman is offline
advice, cinema, room, size
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
