Originally Posted by Jon Boy
Why not just fix 2x2 to the existing ceiling round the perimter like you say and then at 600mm gaps across the ceiling, then use some 50mm rockwoll between the battens and board it!
Jon
The way the OP has suggested will provide a better barrier to the transmission of noise to the upper level. The air gap, if properly sealed is more efficient than thickening an existing surface.
The weight of the ceiling will be determined by which hangers you use. AFIAK the less contact between the 2 layers the better - moreso if the fixing has to penetrate the original surface.
Mattym over in the Acoustics and Calibration forum is a good source of info on most things to do with room acoustics and there are some very readable explanations at
www.audioholics.com
