AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 30-04-2006, 3:54 PM   #1 (permalink)
Thanks: Gave 4, Got 0
Hanging a Projector from a Plasterboard Ceiling
Well, I've bought myself a new H79 projector and the matching ceiling mount. I now need to hang it from the ceiling.
Problem is, the ceiling joists are really in the wrong place to get the position I need.
Has anyone successfully mounted a projector/mount straight onto the plasterboard ceiling (with the right fixings of course)? The manual for the mount says you can, but the projector weighs 7.5 kg (16.5 ib) so I'm rather nervous!
rm48ic is offline
Old 30-04-2006, 4:46 PM   #2 (permalink)
What I did with mine was to screw a length of MDF offcut so that it straddles two joists, then mount the projector to the MDF.
It's not particularly elegant, but it does the job nicely.
damned is offline
Old 01-05-2006, 10:32 AM   #3 (permalink)
louishm's Avatar
Thanks: Gave 31, Got 53
is there no way you can access the ceiling from above, if this was possible you could fix some battoning between the joists for a good fixing
360 Gamertag:sparky2011. PS3 Gamertag:sparkypaul1.
Visit My Home Theatre
Visit My Re-Build
louishm is offline
Old 01-05-2006, 11:46 AM   #4 (permalink)
Thanks: Gave 65, Got 87
this is by far the tidiest way
those boards screwed to the ceiling are horrid!
it's not too bad to go upstairs and lift a few floorboards either, you will regret it if you dont
rhino2k is offline
Old 01-05-2006, 5:09 PM   #5 (permalink)
Thanks guys.
I think I will have get into the loft to try to fix this batton between the joists.
How do you suggest fixing it between the joists?
rm48ic is offline
Old 01-05-2006, 5:16 PM   #6 (permalink)
SeanT's Avatar
Thanks: Gave 62, Got 215
No need to fix it really, just get someone to hold it in the right place whilst you screw into it! If it spreads the weight across the ceiling between the two joists, then it may as well be fixed to them anyway
Relysis 40 inch LCD, Harman Kardon AVR 630, MCPC (CM260, IMON, Tosh HDDVD-ROM, E2200@2.75GHz, 2400XT, 2GB, 320GB, Sweetspot SDI card,Happauge HVR4000, MCE'05), Kef XQ5/XQ2C/Q2DS/Q8S, Cyrus aca7.5, PSXR, CD6, Quad 303 x 3, Sky+ 250 SDI
SeanT is offline
Old 01-05-2006, 5:25 PM   #7 (permalink)
Thanks for that mate but I must be thick - if you dont need to fix it to the joists what stops it from pulling down the plasterboard ceiling, which is only nailed to the joists? The projector weighs 7.5 kg so wouldn't that do the damage?
rm48ic is offline
Old 01-05-2006, 5:40 PM   #8 (permalink)
louishm's Avatar
as seant mentioned its all to do with spreading the weight. rather than using some battons try a piece of square cut ply, this will spread the weight even better.
Visit My Re-Build
louishm is offline
Old 01-05-2006, 6:50 PM   #9 (permalink)
Super Moderator
Thanks: Gave 178, Got 696
If you want it secure, then you screw throiugh the existing joists to the new batons (two screws at either end should do it.)
[FONT="Courier New"]
XXXXXXXXXXXXXXXXXXXXX
EXISTING
NEW
SCREW THROUGH
(IGNORE)
[/FONT]
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline
Old 02-05-2006, 8:05 AM   #10 (permalink)
if you have double skinned plasterboard use toggles I use these all the time in schools
aarons is offline
ceiling, hanging, plasterboard, projector
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
