AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 27-04-2006, 11:32 PM   #1 (permalink)
paul mathews's Avatar
Thanks: Gave 1, Got 0
hiding cables around walls, best way?
My place is pretty hard to do this. As the walls are solid and the floor is tiled. Iam pretty screwed when i have to go over my hllway. A runner hides most of it but not all. I suppose some same colored tape would fix that.
But the wires on the floor arround the wall seems to be the best chance of fixing how would i go about hiding them ?
Thanks.
Just want to make it look alittle more tidy than it looks.
Bye.
paul mathews is offline
Old 28-04-2006, 7:30 AM   #2 (permalink)
inzaman's Avatar
Thanks: Gave 60, Got 232
What wires are you trying to hide, is it just speaker cable or does it include other wires?
Visit my Home Cinema here
inzaman is offline
Old 28-04-2006, 11:10 AM   #3 (permalink)
Pretty much just speaker wire. Normal wire and coax as well. Left side Areial and phone wire to
Just looks untidy the way it is.
Thanks.
Old 29-04-2006, 7:38 AM   #4 (permalink)
I've had the same problem, what I've done is bought some artificial skirting to replace the old. doing so you can put all the wires inside, looks good but not all that cheep. £12 a length !!
RoVic is offline
Old 04-05-2006, 4:19 AM   #5 (permalink)
Thanks. Was thinking that. Going to my local hardware shop and have alook arround
Very helpfull they are.
Old 04-05-2006, 6:02 AM   #6 (permalink)
Thanks: Gave 19, Got 33
Find a short run of the existing skirting and prise it off the wall. Depending on your type of flooring you may find an expansion gap around the edge of the flooring that'll suit you needs.
binbag is offline
cables, hiding, walls
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
