AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 27-04-2006, 10:09 AM   #1 (permalink)
Dan L's Avatar
Thanks: Gave 29, Got 98
Running cables to upstairs - advise please
Hello folks,
Over the next couple of weeks I would like to sort out some cabling to run from my lounge to the bedroom which is directly above. I will be wall-mounting a plasma screen in the bedroom - fo ease I will be locating it on the wall directly above the lounge TV/equipment. It is an external wall with easy access to the outside.
I was hoping to try to feed the cabling required down the inside of the wall - make a hole in the plasterboard then drop them down - however I had a though that there probably is no gap where the bedroom floor/lounge ceiling meets the external wall - would this be a correct assumption?
If this is the case, I'm guessing my only other option is to drill through the external wall, run the cabling up to the bedroom, then drill through the bedroom wall and terminate them upstairs. I am planning on using 3 x UTP ethernet cable to carry the signals I need:
1 x VGA
1 x Component
2 x analogue audio (low powered line-outs from the PC & Xbox360)
...one of the ethernet cables will carry both audio signals (4+4 wires) to save using another cable.
My only worry is that I will have ethernet cables running up the side of the house. The wife may not be too happy about that. What can I do to hide them? What can I use to attach them to the wall? Is there another method I could explore? Cable length should not be a limiting factor.
I also need to source some wall terminal plates - namely audio (3.5mm jack sockets & phonos) and component connectors. Any suggestions for suppliers would be greatly appreciated.
Many thanks
Dan
Panasonic TH50PZ80B, Panasonic 42PHD8 & Hitachi 42PD7200
HTPC: Athlon 64 3200+/Silverstone LC03-V
link to commercial site removed by Admin
Dan L is offline
Old 27-04-2006, 12:07 PM   #2 (permalink)
mhuk05's Avatar
Thanks: Gave 29, Got 125
How about a photo?
CAT5 cable is unshielded so be careful where you run it.
mhuk05 is offline
Old 27-04-2006, 12:32 PM   #3 (permalink)
badkarma's Avatar
Thanks: Gave 60, Got 56
http://www.cabletidy-direct.co.uk/ check under cable bridges, something like this might do the job. You'd need to fill the ends with silicone or the like to prevent ingress of water and could paint it a similar colour to your walls for a bit of camoflague
You could use STP cat5 for better noise immunity. Also does cat5 have enough cores for VGA ?
badkarma is offline
Old 27-04-2006, 12:43 PM   #4 (permalink)
Dan L's Avatar
Yep, only needs 8...I've already made adapters which work flawlessly
Assuming the cables run externally, would noise even be an issue?
Dan L is offline
Old 27-04-2006, 1:15 PM   #5 (permalink)
mhuk05's Avatar
There is also d-line from tlc-direct
mhuk05 is offline
Old 27-04-2006, 1:42 PM   #6 (permalink)
badkarma's Avatar
Tried them at the required distance ? not had much luck PQ wise with vga over a few meters, although I've never tried VGA over CAT5 direct, only ethernet VGA extenders.
Doubt it, you should try and avoid a.c. cabling though.
badkarma is offline
Old 27-04-2006, 1:43 PM   #7 (permalink)
Dan L's Avatar
Thanks for the suggestions guys.
Dan L is offline
Old 27-04-2006, 1:49 PM   #8 (permalink)
Dan L's Avatar
Yeah, longer runs of VGA are rubbish, anything over 2 metres and you get loads of ghosting. I tried a test with a 5m length of ethernet cable and the image was 100% perfect. I doubt I'd need much longer than that if I go directly out and up.
Dan L is offline
advise, cables, running, upstairs
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
