Hi m8, the bracket should have some screws with plastic spacers if needed for this model aswell, these fixed to the back of the screen, you will see 4 round plastic grey covers on the back of the plasma, remove these with a screwdriver then fix the bracket or allen screws to the plasma.
If this is the one,
http://www.imount.co.uk/index.php?ma...3b6b94e471cd96
Then you would fix the tilting brackets to the plasma, the back bar to the wall, then lift the plasma onto the bar and then there maybe some screws to lock the hooks into place.
Hope this helps
Taz
