AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 25-04-2006, 10:26 PM   #1 (permalink)
Taz69's Avatar
Thanks: Gave 19, Got 24
suggestions needed for Plasma install please
Hiya all
I am trying to decide where to mount my 42PV500, my lounge is a long shaped room of 12' by 17' approx, the fire breast is in the middle as seen in the picture (P1), this was where I was going to mount the TV above first of all, now my brother has thrown in the suggestion of mounting it in the alcove to the right of the breast (P2)on a frame made up from 4"x2" timber etc with all my kit behind the plasma at the bottom, I can sort out the control etc via IR,
What I am wondering is due to the fact that I would like to retain a projector and screen possibly, does the centre speaker need to be in the centre of the visual ie under the PV500 and the PJ screen or is possible to connect 2 centres via a switch box.
Any suggestions welcome, where would you mount the TV.
Thanks in advance
Taz69
My Home Cinema Build http://www.avforums.com/forums/home-cinema-diy/634919-taz69s-home-cinema-lounge-last.html
Taz69 is offline
Old 26-04-2006, 1:19 PM   #2 (permalink)
Taz69's Avatar
27 views and no replies, come on guys and girls I am in need of some serious help here before I go out of my mind, lol. no honestly I am looking for ideas on where to put my screen, I really want the room to look right afterwards, where do you guys have your plasmas/lcds and PJ screens, are they always behind the screen when pulled down etc.
Taz
My Home Cinema Build http://www.avforums.com/forums/showthread.php?t=634919
Taz69 is offline
Old 26-04-2006, 2:13 PM   #3 (permalink)
Thanks: Gave 3, Got 3
nice to see another lfc fan i would have the plasma above the fireplace but be warned of the heat from the fire but if you dont use it theres nothing to worry about then have all your gear next to it in the alcove then if you have a pj screen have that coming over you tv that what im doing as long as you donrt sit too close you will be fine or you might get neck ache show pictures when done
anfieldfc is offline
Old 26-04-2006, 2:41 PM   #4 (permalink)
Taz69's Avatar
Hi m8, cheers for the reply, that was my first thought, now my brother mentioned it my wife is thinking "oh that could be good, hide all his kit away" lol
Dont suppose your going to the match this Monday are you, we are, getting excited now the time is drawing near.
Taz
Taz69 is offline
Old 26-04-2006, 2:52 PM   #5 (permalink)
dj_johnnyg's Avatar
Thanks: Gave 1, Got 4
What's to the Right of the picture, is it a large window opposite the sofa on the left, or is it an internal wall?
I would go for putting the screen in the centre of the wall (i.e. above fireplace) so if you have surround speakers, the setup would be easier.
If it is a large window on the right, you may need to worry about light flooding the screen (especially the PJ), unless you have some good curtains
CINEMA GOERS. Please have consideration for pirate DVD viewers by having a **** before the film starts.
www.bradwoodmtrsport.plus.com
dj_johnnyg is offline
Old 26-04-2006, 3:03 PM   #6 (permalink)
Taz69's Avatar
Hi DJ, it is a large window about 2mtr wide, that was one of the things my bro said about the glare from the window, its looking like the centre of the room is favourite, I have lined curtains and I was thinking about Black Vertical blinds but have been having trouble sourcing them from online.
Taz
Taz69 is offline
Old 26-04-2006, 4:35 PM   #7 (permalink)
Taz69's Avatar
Hi people, I have added 2 pictures to the first post this is of the actual lounge, 1 with the bracket where the plasma was the other with a sheet of 18mm ply fixed to the alcove to show my wife what it will look like, the plasma will be fitted to this if I go that way.
Any opinions ??
Taz
Taz69 is offline
Old 26-04-2006, 4:41 PM   #8 (permalink)
mhuk05's Avatar
Thanks: Gave 29, Got 125
Why mount it so high?
mhuk05 is offline
Old 26-04-2006, 4:43 PM   #9 (permalink)
Taz69's Avatar
Hi chap, its not that high, to the base of the plasma its only 905mm the hole for the fire is only small, looks decieving from the photo.
Taz
Taz69 is offline
Old 26-04-2006, 6:22 PM   #10 (permalink)
Taz69's Avatar
Hi all, looks like its going to be the Firebreast after all, are there any other members out there with a lounge used for both plasma and PJ etc.
thanks for the suggestions upto now.
Looking for ideas
Taz
Taz69 is offline
Old 26-04-2006, 8:43 PM   #11 (permalink)
inzaman's Avatar
Thanks: Gave 60, Got 232
I personally would put it above the fireplace as personally i think it will look strange in the corner. Where are you planning on putting your centre speaker?
Visit my Home Cinema here
inzaman is offline
Old 26-04-2006, 9:02 PM   #12 (permalink)
Taz69's Avatar
Hi chap, I am thinking of the centre speaker below the plasma in the centre so when I decide to put the screen down for the pj it will still be on view, the other idea I just had was putting all the kit on the wall opposite the long window, and the pj mounted above the curtains, any ideas on what height the PJ should be ?? anyone
Taz
Taz69 is offline
Old 26-04-2006, 9:18 PM   #13 (permalink)
inzaman's Avatar
Sounds fine to me, the screen will then come down over the plasma; what PJ are you thinking of getting as that may determine the height.
inzaman is offline
Old 26-04-2006, 9:48 PM   #14 (permalink)
Taz69's Avatar
Thats what I was thinking making things easier for screen etc, at the moment it will be the AE100, may well be the AE900 soon. any ideas on what height the screen should come down to, I am looking at the Beamax R series, 6ft or maybe the 7ft one.
Taz
Taz69 is offline
Old 26-04-2006, 10:01 PM   #15 (permalink)
mhuk05's Avatar
As low as you can get it (5- 600mm from the floor?)- it's your neck
mhuk05 is offline
install, needed, plasma, suggestions
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
