AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 23-04-2006, 3:20 PM   #1 (permalink)
Spoonboy90's Avatar
Thanks: Gave 24, Got 14
Cutting Ikea Blackout Blinds
Took a trip to Ikea today and brought some blackout roller blinds.
Does anyone have any words of advice on cutting them down to length?
Jamie
Spoonboy90 is offline
Old 23-04-2006, 3:55 PM   #2 (permalink)
sbowler's Avatar
Thanks: Gave 119, Got 430
Yes, be careful. I would get a length of wood amd a very sharp stanley knife use the wood as a guide and cut down the length of material, the wood should ensure you get a nice straight cut.
My flickr Pentax K10D Sigma 10-20/24-135/70-210/Pentax 50mm f1.4/Sigma 24-70mm DG-EX
MyA/V
"Chance favors the prepared mind"
sbowler is offline
Old 23-04-2006, 4:26 PM   #3 (permalink)
Thanks: Gave 0, Got 6
Not sure if they are like this but if the material is rapped around what looks like the inside of a toilet roll then i used a juior hacksaw to cut through this and a stanley knife to trim material
putbinoot is offline
Old 23-04-2006, 6:28 PM   #4 (permalink)
shahedz's Avatar
Thanks: Gave 578, Got 341
i a used hacksaw to cut it while rolled up. and then used a piece of wood and stanely knife to get a sharp edge, i used cardboard underneath when trimming it so the balde had something to go into and really went all the way through the cloth
Linn Kolektor pre amp & LK140 amp,Genki,Sony MD MDS JE510,Roku Sound bridge M1000,Ariston RD-40 turntable,TDL RTL3 ,Samsung32R87, Yamaha YSP-1000,Panasonic PT-AX100E projector,Toshiba HD-E1 ,Sky HD, XBox 360, PS3,Harmony 885
shahedz is online now
blackout, blinds, cutting, ikea
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
