AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 22-04-2006, 9:49 PM   #1 (permalink)
Knyght_byte's Avatar
Thanks: Gave 83, Got 490
Venetian or other Blinds help needed
Hiya folks
first time posting in the DIY section, please go easy on me...heh
summer is here, good in some ways, bad in others........in this case its bad because my bedroom in which i have my projector and will do for the next summer as well as this most likely is the room that the sun sets on :-(
so a blind is needed to allow the watching of movies before 10pm..lol
trying to keep it simple, the window setup is as thus, approx 9-10ft wide and just under 6ft drop.........there is a windowsill, mebbe 5inches deep......the windows are UPVC surrounds so i cannot fix that direction.......the mountings must go either in the sides of the 'bay' or straight up.........(the blind is basically inside the sill area, not the actual bedroom wall itself, thats where the projector screen is...).........obviously with this size width it will require a fixing halfway along....or two fixings at thirds.......
does anyone know where i'd be able to obtain a blind (preferably venetian) of these dimensions that can be affixed this way?......most usual places such as DIY warehouses only seem to do widths around 5ft or 6ft.........ok if i have to have two blinds i will, but i'd rather have one to keep it simple.....anyone got any ideas? help much appreciated :-)
cheers,
Knyght.
HC: Infocus 7205, Denon 3803/3910. MA Silver S6, SFX, S2, SLCR. SVS PB12/Plus. Sky+.
Hifi: Musical Fidelity A5, Denon 3910 CD/SACD/DVD-A. Monitor Audio GR10's.
PC: E6700, Gigabyte DS3 965P, 2Gb Corsair, Gainward 8800GTS 640Mb, CL X-Fi Fatal1ty, Jeantech 600w, Antec Sonata II.
Knyght_byte is offline
Old 23-04-2006, 10:28 AM   #2 (permalink)
Thanks: Gave 110, Got 108
you might be able to buy a larger blind and cut it down from DIY superstores or there are manufacturers of custom blinds?
mattym is offline
Old 23-04-2006, 1:01 PM   #3 (permalink)
Thanks: Gave 27, Got 71
Take a trip to John Lewis and visit the blind department.
You can of course buy custom made blinds (or all sorts).
For the size you are talking about, sit down before they tell you the price.
James
GasDad is offline
Old 23-04-2006, 1:08 PM   #4 (permalink)
Thanks: Gave 4, Got 43
I covered the width of my windows with three smaller venetian blinds as a custom one was going to be several hundred quid. To get the right size I trimmed one blind down with a 'blind trimmer'/'Slat cutter' that cost about £4.
BTW Venetian blinds aren't light proof if that's what your after.
Mat
avanzato is offline
Old 23-04-2006, 6:29 PM   #5 (permalink)
clockworks's Avatar
Thanks: Gave 32, Got 166
You might be better off with curtains. Probably cheaper at that size, as well as being (depending on the material) more light-proof.
If you dont fancy curtains, a couple of blackout blinds should do the job
Panasonic TH-46PZ81B, Arcam AVR350, Linn LK100, Naim NAP110, Quad L-ites, PS3, Samsung 850, Sky+, Humax 9200T, Panasonic E50, Harmony 1000, Pixel Magic HD-MB200, M-Audio Flying Cow DAC, Pronto TSU9600, Mac Mini, iMac
clockworks is offline
Old 23-04-2006, 8:11 PM   #6 (permalink)
i had the feeling if i could get a big one made up it would be a bit costly...heh, i might get a couple quotes tho, if i can get it around £120-30 i might be able to do that....
i'm not too worried about it being completely light proof simply because my walls are apple white so i already get reflection from the projector on those anyhow...lol
but if i can get ones that i can vary the slat angle then at least i can get rid of most light and then once the sun has gone down open up a little for more ventilation....
dont want curtains really, they would need a pulling thing to close them as i cant get to the windows easily enough.....that would probably end up costing close to the blind..lol...
black out blind would obviously be the best option, but again getting one wide enough isnt going to be cheap, but also it will cut off any chance of breathing i have.....lol...this room gets seriously hot cuz of my equipment and the sun setting on it, so a proper blackout blind would mean no air getting in or out of the room (need to keep the door closed to keep the cat out.....too many wires for him to play with in here...heh)
thanx for the response tho folks, much appreciated :-)
blinds, needed, venetian
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
