Hi All,
I need some verification, I am about to help by brother hang his new 42" PX60 to a plasterboard wall.
My query is this:
The flat used to be an old Mill so all of the walls are plasterboard. The wall we want to put it on has a brick wall about 120mm behind it with insullation between the walls covered in plastic.
The best idea I can think of is to
1. remove a piece of the plasterboard the size just over the size of the wall bracket.
2. Fit a piece of wood to the 3 battons the same size as the hole 15mm thick.
3. Fit the Bracket & Plasma to the wood.
Can you tell me if this would be strong enough to hold the TV, and what type of wood to used?
Click on Pic
Thanks for your help
Dan
