AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 19-04-2006, 3:32 PM   #1 (permalink)
sould i use converted loft for hc
hi all, i converted my loft a couple of years ago, at the moment it is used for a computer room however after seeing photos of gizlorac's loft hc i was wondering about using it for the hc projection system i currently have in the living room, my main concerns are sound leaking through to other rooms and next door (semi) and also is it large enough for a 7ft wide 16:9 projection screen the size of the room is approx 11.5 ft long, 10 ft wide ,and about 7.5 ft high at the center, any advice and inspiation would be great......
rustyhead is offline
Old 19-04-2006, 3:42 PM   #2 (permalink)
sbowler's Avatar
Thanks: Gave 119, Got 430
Hi and welcome to the forums. I have used my loft after converting it around 7yrs ago. I dont have any probs with regards to sound leakage and ours is a terraced house. As long as you keep to reasonable hours of the day, its not often that I use the room much after 2230 anyway. The only thing with the loft is in the summer is that it can get a bit hot. Mine is around 18 X14 and I have an 82inch screen. and sit around 3mtrs from it. You can see details of it in my signature. I would go ahead if I was you, Ive never regreted it.
My flickr Pentax K10D Sigma 10-20/24-135/70-210/Pentax 50mm f1.4/Sigma 24-70mm DG-EX
MyA/V
"Chance favors the prepared mind"
sbowler is offline
Old 19-04-2006, 3:54 PM   #3 (permalink)
thanks
thanks for the speedy response sbowler,nice hc room m8, i think i might go ahead with the room it's the only room in the house that i have complete control over (wife and kids control the rest lol) i've added 2 photos so you get an idea of the room.
Old 19-04-2006, 4:06 PM   #4 (permalink)
Johnny Thunder's Avatar
Thanks: Gave 206, Got 140
Go for it rusty.
And keep us up to date with progress pics.
::Pioneer PDP 50MXE1::Lumagen VisionPro HDP::Denon AVR 3805::Arcam Diva DV79::Sky+HD::Microsoft XBOX 360::Acoustic Energy AELITE Three's, One's, Centre and Subwoofer::
Johnny Thunder is offline
Old 19-04-2006, 4:13 PM   #5 (permalink)
thanks johnny, as soon as work starts i'll post pics, first i have to decide where the screen and the seating area are going, would like to have the av gear and tannoy mercury speakers fitted into the walls,also looking into the benifits of using carpet on the lower walls, but do not want to spoil the looks of the room.
Old 19-04-2006, 4:21 PM   #6 (permalink)
If you hide the chimney breast with a flush false wall to take the screen, you
could build your fronts into the void.
Old 19-04-2006, 4:23 PM   #7 (permalink)
I am sure you have seen it mate, but if not, check out THIS for inspiration.
This one is gorgeous.
Old 19-04-2006, 4:46 PM   #8 (permalink)
yes m8 came across it the other day,makes me wish the loft was half that size lol,but that is the kind of look that i would be after maybe with darker walls for light control a dark wine red maybe,would like to put the screen on the chimney wall ,just wondering about the seating at the other end of the room due to the hatch enterance (see pic) ,however the other way round wound make the screen low, the speakers would not really be a problem as there is enough room behind the wall to place them.also added a pic of the polysteirene insulation i used it keeps the temperature quite comfortable but have no idea about the acoustic properties.
Old 19-04-2006, 4:52 PM   #9 (permalink)
I am unsure about soundproofing, hopefully another member will jump in here.
Old 25-04-2006, 9:15 PM   #10 (permalink)
chowyunfatt's Avatar
Thanks: Gave 399, Got 504
I coverted my loft, and i love it.
It's not very big but i will get some pictures together and you can see whats possible even with tight spaces.
PSN: CHOWYUNFATT, GT-DC, AVF BluRays, AVF SOCOM, Hot: MotorStorm P:R, GOTY:LBP,
chowyunfatt is offline
Old 25-04-2006, 9:18 PM   #11 (permalink)
the pictures would be great.
Old 25-04-2006, 9:28 PM   #12 (permalink)
mhuk05's Avatar
Thanks: Gave 29, Got 125
Whatever insulation you use, make sure it is fireproof! Is that polystyrene fireproof? Have you seen how quick it burns?
mhuk05 is offline
Old 26-04-2006, 8:42 AM   #13 (permalink)
Some pics,
Old 26-04-2006, 8:52 AM   #14 (permalink)
wow ! great install m8....... did you do all the work yourself ? this is exactly the inspiration i needed.
what size is the loft?
Old 26-04-2006, 8:59 AM   #15 (permalink)
hi mhuk05 brought the polystyrene from b&q was acutally sold as insulation blocks for cavity walls, floors and roof space so hopefully it's ok...
converted, loft, sould
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
