AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 18-04-2006, 7:19 AM   #1 (permalink)
What to use for cable exits?
Wall mounted my plasma this weekend and I have chased out the wall for the TV cables, but what should I use where the cables exit at the top and bottom of the wall to make it neat?
Also I have wallmounted some speakers, is there anything I can use where the speaker cable exits to make it tidy?
Cheers,
Mike.
coopertrooper is offline
Old 18-04-2006, 4:41 PM   #2 (permalink)
Wopsta's Avatar
For my speaker cable exits I just glued a washer in place just below the surface so there was a clean exit for my cables and to prevent tugging away at the plastered channels. Not sure about your plasma cables though as I guess you'd want something a bit neater where it's on show...
Panasonic TX-32LXD500 LCD TV, Denon 1906 Amplifier, Kef KHT 2005.2 speakers QED micro cabling, Xbox 360
Wopsta is offline
Old 18-04-2006, 5:15 PM   #3 (permalink)
tnoy66's Avatar
Thanks: Gave 52, Got 20
Check this thread
Cable Exits - Wall Plates
tnoy66 is offline
Old 19-04-2006, 7:21 AM   #4 (permalink)
gaz
Thanks: Gave 3, Got 0
Hi i like the idea of the washer (painted) idea earlier in the thread which made me think of these:
http://www.realoakfloors.co.uk/pages...ipe_covers.htm
they are also available from good plumbers merchants and hardwood/laminate floor specialists ranging from 8mm - 28mm diameter in a variaty of wood shades or white and even chrome but don't be put of by ones ive seen at B&Q as they were just printed paper ( a bit flimsy )
some things just get better with age my 4th projector might come of age one day...........
check it out.......
http://groups.msn.com/diyprojectiont...12426764388324
gaz is offline
cable, exits
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
