Amit could you dome a favour and do me alittle scetch
I looked at those drawer slides and this one seems to be the stongest. Not sure it would be sutible as iam not sure how it looks when together. I was thinking of putting four in the build one at each corner to take the weight. Slould be more than enough for a 75kg TV. being 40 kg capable each
http://www.screwfix.com/app/sfd/cat/...6338&ts=71733#
And as they can be also screwed in on the bottom extra stability. All i would then need is to make a holding craddle for the TV to connect the other part of the slide to. So the tv can then be raised up and down. Hopfully via a remote control. Corded or other wise. Well thats what iam thinking i could have this all wrong.
Would be nice if you could do alittle scetch for me to push me int he right design dirrection.
With the Acuator i would need some help their to. not sure where i could put that !!!!
Also dont know which one i would need either ?
Thanks for the help and more help if ya like
Thanks.
