AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
LinkBack Thread Tools Display Modes
Old 11-03-2002, 10:20 PM   #1 (permalink)
ReTrO's Avatar
Thanks: Gave 1, Got 23
DIY stands
As attentive people will know I have made my own quipment stand/rack.
I am currently designing one for Taz, it's gonna be a scorcher! (Hey not used that word for a while!)
If anyone has any usfull contributions on what might be a good addition please feel free to post here.
It's currently going have 'floating' levels and spiked levels for the CD and DVD.
Richard Wilson
Assured Advertiser
PJ HiFi - Home Automation & Cinema Specialists
----- The forums longest serving member -----
ReTrO is offline
Old 12-03-2002, 12:46 PM   #2 (permalink)
philmate's Avatar
Thanks: Gave 0, Got 2
Retro,
Have a look on www. tnt-audio.com. in the tips and tweakings, there's a section on racks.
Philmate.
"Beware the Wok child"
philmate is offline
Old 12-03-2002, 2:37 PM   #3 (permalink)
I'm designing one at the moment for the tv with shelves underneath for the rest of the kit. Main concern is for it to be nice and strong (don't want the loewe to end up on the floor), so i've got a friend of the family to weld a steel frame, and i'll attach a wooden border around the front for aesthetics (similar to those from ashdesign, only a hell of a lot cheaper to make yourself). Shelves will be glass if the price is right for the size and necessary British Standard.
The best idea i've got is for a panelled-in cable section on the back to keep everything tidy. Shouldn't be hard to incorporate something like that into your design.
cheers,
pg.
philgibson is offline
Old 12-03-2002, 3:07 PM   #4 (permalink)
Taz
Taz's Avatar
cheers,
pg.
Thats something we should look into Rick
Taz.
My opinions expressed here are not necessarily those of the AV Forums or the associated websites.
Elvish has left the building...
Taz is offline
Old 12-03-2002, 8:05 PM   #5 (permalink)
ReTrO's Avatar
A 'cable tidy' section would work very well with TV stand that has a basic system, ie DVD, TV, VCR ,SKY all connected by SCART. The problem with using cable management with complicated AV systems is that there is rarely enough room for all the cables. I'll look into it but on a conventional style hifi stand it would probably add excess bulk, and not really look to good either.
I'll look into it though, and make sure you have plenty of room for your cables philgibson.
Richard Wilson
Assured Advertiser
ReTrO is offline
Old 13-03-2002, 9:05 AM   #6 (permalink)
thanks ReTrO,
I've done a quick sketch for you based on the design for my rack. If you were to box in the shaded section between the two rear supports, this should give plenty of room for cables. I saw something similar in 7oaks the other day, which had a slide-in rear panel to the box section. I reckon this design should be stronger than the 'leg in each corner' approach, but it would take quite a bit more work.
BTW, I haven't made the stand yet, it's still in pre-production!!. Still saving for the av amp and centre, so I have room at the moment for the stereo amp, dvd and ps2. My girlfriend's dad is currently working in a school technology dept., and has his eye on some materials and equipment so it's just a case of getting round to it.
Hope this helps,
Will keep you posted!, and please .. let me know how you get on.
pg.
Old 13-03-2002, 4:53 PM   #7 (permalink)
ReTrO's Avatar
I see what you are getting at phil.
I will post some links to pics of my stand I have made soon.
Rick
Richard Wilson
Assured Advertiser
ReTrO is offline
Old 18-03-2002, 3:27 AM   #8 (permalink)
Posts: n/a
If your having trouble with the price of toughened glass, you could use safety glass (the one with the criss cross wire running through it) which is very much in vogue at the moment, and is often used by designers and architects, on table tops, and as room partitions in loft apartments. It can not just smash,so your tv won't fall through it.
Old 18-03-2002, 7:56 AM   #9 (permalink)
thanks sean,
i like the sound of that,
although i'm basing it on a design that's around in the shops, i'd like to make it a bit custom! haven't got the price for standard toughened yet, but will look into it.
pg.
Old 19-03-2002, 4:47 PM   #10 (permalink)
rob_w's Avatar
Thanks: Gave 1, Got 1
safety glass is not that cheap!- i bought a 1 metre square of it as a splashback for my hob, cost £60 with 3 polished edges, and four drilled holes(£2.50 per hole) I thought it was meant to be fire proof, but the heat from my hob has cracked it :-(
rob_w is offline
Old 19-03-2002, 6:41 PM   #11 (permalink)
Posts: n/a
I'm sorry i meant security glass, and i don't think it's fire proof. You wont need to drill holes, if you make a lib for the glass to drop in to.
Old 20-03-2002, 9:29 AM   #12 (permalink)
Posts: n/a
10mm Toughend glass with 4 ground edges 21" X 17" just cost me £28 each, I needed 8 of em, I guess I should have checked the price before I decided to build the cabinet with glass shelves , 10mm may be over the top as 6mm would probably have been ok but better safe than sorry.
Another thing I never really thought about before I started building a stand for my kit is the overall weight of the thing now its finished and loaded with gear, I would think the overall weight is about 250 to 300 Kilos I mounted it all on 6 heavy duty casters so I could easily pull it away from the wall to gain access to the rear but the weight of the thing still makes it a pain to move.
Old 22-03-2002, 12:46 AM   #13 (permalink)
Chris Frost's Avatar
Thanks: Gave 34, Got 77
Originally posted by Another_Mick
now its finished and loaded with gear...the overall weight is about 250 to 300 Kilos
So the stand won't collapse, but the floor might give way underneath.
Oh, bu**er! Nothings ever simple is it.
Regards
Chris Frost
Chris Frost is offline
Old 22-03-2002, 9:22 AM   #14 (permalink)
ReTrO's Avatar
You got any pics of your stand Mick?
Richard Wilson
Assured Advertiser
ReTrO is offline
Old 22-03-2002, 7:43 PM   #15 (permalink)
Posts: n/a
Not so much a stand as a cabinet and i'm fortunate that I have a concrete floor .
As for pictures...........well, maybe when I figure out how to get the doors to hang straight
diy, stands
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
