Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 25-03-2006, 12:40 AM   #1 (permalink)
Thanks: Gave 40, Got 34
Plasma install - False chimney breast
1. Here's the wall in my new house, 1st job, remove the fireplace !
2. Fireplace removed...
the result i'm looking for is something between this Finally finished - V40 Wall
and
My new plasma wall . . .
both of which are outstanding and a credit to those two guys.......
3. Build frame myself, or let my joiner friend do it.. Also, pull up some chipwood floor boards to lay my speaker cables etc ......
oh boy, would you like to rip those floor boards up (and add a bit of sound proofing to boot ) ??
Thought not LOL
Fujitsu P50XHA40US (The dogs nads of displays) has arrived.
Ok, today, i decided to fit the bracket - by Unicol.
Went the Resin fixing way, instead of sleeve anchors (we use this stuff at work, well, the maintainance guys do, they anchor industrial machines and cranes to the floor, so, hopefully, it will hold my plasma)
Got a shock when i started to drill, as it was like a hot knife in butter - on further inspection, i was drilling into thermalite !!! After panacking a while, i jumped on the forums and searched thermalite, and, alls well, i'm using the fixing method recommended for this stuff.... (still scared, i continued drilling, and added two extra fixings, so 6 instead of the 4, as you can see in the attached photo's, didnt get the bracket bang on, but only 5 mm out of the intended horizontal posistion, not bad if i say so myself)
__________________________________________________ ___________
Finally got some boards up, Check out the Joists, sure dont make em like they used to, but, makes the job a hell of a lot easier, now wheres my drill ????
Fujitsu P50XHA40US , Arcam FMJ DV139, AV8, Bryston 4B SST,5BST, PMC OB1 Fronts, CB6,DB1+ Rears, SVS SB12 Sub, Chord Cables.
http://www.invelos.com/dvdcollection.aspx/djblade
DJBlade is offline   Reply With Quote
Old 25-03-2006, 9:42 AM   #2 (permalink)
Johnny Thunder's Avatar
Thanks: Gave 236, Got 148
Good luck mate.
Johnny Thunder is offline   Reply With Quote
Old 25-03-2006, 12:17 PM   #3 (permalink)
owain_thomas's Avatar
Thanks: Gave 56, Got 54
I'll be interested in this thread, its exactly what I intend doing when we move.
flickr
HC - Rotel RSP-1068 Processor, Mac Mini running Plex, Arcam A90, Totem Arro Speakers
TV - Panasonic TH42PHD8 with Lumagen HDP
owain_thomas is offline   Reply With Quote
Old 25-03-2006, 11:35 PM   #4 (permalink)
Get the floor boards up mate, while you are making a mess, go the whole
lot.......
Old 26-03-2006, 12:08 PM   #5 (permalink)
scharf_10's Avatar
Thanks: Gave 218, Got 83
Good luck man, keep the pictures coming.
My flickr || Canon EOS 400D | Sigma 10 - 20mm | Canon 50mm f/1.4. | Canon 24 - 105mm f/4 L || My Website
scharf_10 is offline   Reply With Quote
Old 26-03-2006, 7:00 PM   #6 (permalink)
How is it going DJ. Decided on how far you are going to go yet.
Lifting floorboards will not be a problem for you. Plenty of people on here
will give you ways and means.
As for making your own false breast, I have never made one.
Maybe there is someone in HERE who can help you, if you are local to them.
Keep us up to date mate. And plenty of pics........
Old 02-04-2006, 6:46 PM   #7 (permalink)
Any updates yet DJ?
Old 02-04-2006, 9:41 PM   #8 (permalink)
update
no, my bracket did not show up, marked out the wall, and ready to lift some boards wednesday..
been on shift at work, and my son turned 21 saturday......
watch this space..........
some pics to follow...
Old 12-04-2006, 1:53 PM   #9 (permalink)
restarted
hi, got round to using the circular saw today, see pics above, hope to get moving fast, as i'm back on nights in two weeks, and the job will stop again........
Old 12-04-2006, 2:56 PM   #10 (permalink)
Keep the updates coming mate.
Have you decided on who is going to build the false breast yet?
Old 12-04-2006, 3:08 PM   #11 (permalink)
update,
yes, looks like i'll be doing it, as my mate can only do evenings, and he wants me to be there...... i aint doing owt when i've just done a twelve hour shift !!!!!!!
Old 12-04-2006, 3:54 PM   #12 (permalink)
You will do just fine mate. Your friend will keep you right.
You could also get him to check it before you fix it all into it's final position.
Old 21-04-2006, 8:30 PM   #13 (permalink)
Action At Last
Sorry for delays in updates, but due to a new (Large) Mortgage, and the chance of lots of overtime, things got put on the back burner.
I've continued with setting the cables under the floorboards - Heres a photo of pulling the Sky+ Coax through the Dot & Dab Walling.
!. Drill 25MM Exit hole - Using 25MM Wood Bit (I'll fit a nice exit bush of some sort to complete, may even use a washer glued in place)
2, Drop string (In this case, some QED Micro cable from my previous system, I KNEW it would come in handy some day) down through wall till it exits under floorboards.
Hope this helps someone with a future install.
3, Tape the 2 Cables together and pull through
Old 22-04-2006, 11:22 AM   #14 (permalink)
Keep the updates coming DJ.
When are you getting your chippy hat on. Come on, stop stalling get the
false breast made.
Looking good so far.
Old 13-07-2006, 5:53 PM   #15 (permalink)
update...
Hi all, been a while, heres an update (sure to sadden a few followers here)
I decided to abandon the false chimney idea for a few reasons, heres a couple :-
1. Decided it would eat too much into the room (4.6 X 4.3 mtr) and i'd have to have my speakers closer to me than i'd like, and also cause complications with furniture
2. Was worried about a hallow space and the affect on sound.
3. This way is a lot easier (although i hope i dont have to do it again for a while, way too much hassle)
P.S.
One of the things i've noticed about a lot of installs while viewing various install threads here, is how close to the wall, and no toeing in of the speakers, photo's of mine to follow, i'm just completing the install of my kit, sofa on order, and blinds/curtains to order......
Comments welcome......
breast, chimney, false, install, plasma
