Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 09-03-2006, 9:09 AM   #1 (permalink)
Picman
Posts: n/a
Power cables and AV cables togrther?
Hi All,
Can anyone tell me if it is acceptable to run power cables and Av cables in the same trunking or am I better off keeping them seperate?
TIA
Old 09-03-2006, 9:17 AM   #2 (permalink)
Thanks: Gave 1, Got 493
It really depends on two things:-
1) What load is on the power cables in question
2) How good the quality of your other cables are
The general recommendation would be to run the seperately, and you certainly should not run video / audio cables in the same trunking as high current cables such as your ring main.
It's all about the induced current - running a single cable to a projector which is drawing less than 200W should't induce anything into nearby cables. Running a cable alongside a feed for an 8000W electric shower will!
Steve
stevelup is offline   Reply With Quote
Picman (09-03-2006)
Old 09-03-2006, 9:57 AM   #3 (permalink)
Thanks: Gave 10, Got 6
I run mine altogether and have no problem at all but avoid cables which are not well shielded...the more expensive usually the better shielded they are. Try it out first and if it doesnt work then isolate the cables with 2 or more plastic cable channels from B+q or another store.
Kid Rock
kid rock is offline   Reply With Quote
Picman (09-03-2006)
cables, power, togrther
