Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 08-03-2006, 10:15 AM   #1 (permalink)
Sly
Sly's Avatar
Thanks: Gave 41, Got 17
planning permission?
i had a thought that due to me living in a terraced house i could build a brick 'workshop' at the bottom of the garden and build it into a home cinema.
i was wondering if i would get planning permission for something like that?
any ideas of the process involved?
kit:sanyo z4,sammy lcd tv,Onkyo 905,Panasonc bd60,M&K XENON series with tripole surrounds,BK xls200,360 elite with HD drive.
Sly is offline   Reply With Quote
Old 09-03-2006, 8:46 PM   #2 (permalink)
Thanks: Gave 1, Got 2
you could build under "LAWFULL DEVELOPMENT" as long as the following is true:
1) the "SHED" is no higher than 4m if pitched roofed or 3m if flat roofed;
2) the existing house has never been extended before
3) and the "SHED" is a temporary structure at least 1m from all boundaries
4) and the "SHED" does not take up more than 50% of the garden or 50m^3 using external dimensions.
If a full planning application where submitted then the "SHED/WORKSHOP" could legally be called a "HOME CINEMA"; but this would need to comply with buildign regs as a habitable room and insulation and sound proofing would also need to comply.
However, you should get in touch with you local planning office as each one has some slight variations to the lawfull development requirements due to local bye laws. They will also be able to put you in touch with a local "Planning Consultant" if you want to proceed with an application for a "home cinema in a shed".
Good Luck
Fight Club..Tyler Durden: The things you own end up owning you
.borg is offline   Reply With Quote
Old 09-03-2006, 9:35 PM   #3 (permalink)
Sly
Sly's Avatar
Wink
1) the "SHED" is no higher than 4m if pitched roofed or 3m if flat roofed.
a)would have thought so.
a)never has.
it would have to be close to the fences either side as it is a long narrow garden.
about 12' by 18' , i guess.no good at maths i'm afraid.
would have thought this puts me in the 'planning premission' route then,at least i know who to speak to now , thanks mate.
permission, planning
