Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 07-03-2006, 12:39 PM   #1 (permalink)
Mr_Wistles's Avatar
Thanks: Gave 73, Got 384
Advice on new install
I am currently in the process of having my kitchen/diner redone. It is a large 25x34 room. I am having a fireplace put back in and I want a plasma over it.
In the room next to it I have a 436-XDE with Sky Plus. I can easily drill a hole through the wall and feed through cables but the question is what cables?
Also when it comes to powering the plasma how can I hide those wires?, does it have to go into a plug or is there some electrical wizardry that allows me to have it done in the wall that I can then just plaster over.
Please bear in mind that I am to DIY what Hitler was to world peace.
Thanks for your time,
Russell
Mr_Wistles is offline   Reply With Quote
Old 08-03-2006, 9:03 AM   #2 (permalink)
Thanks: Gave 2, Got 4
If you want to "hardwire" the Plasma, you'll need to wire the plug into an isloated spur. Basically like a blanking plate with a fuse. Don't ever by-pass the fuse!
Or, you could just simply have a recessed plug in the wall, how are you going to be mounting the plasma to the wall?
Oakmere is offline   Reply With Quote
Old 10-03-2006, 2:49 PM   #3 (permalink)
Mr_Wistles's Avatar
Isolated spur?!? I take it I need a spark for that?
I am going to mount it to the wall with a standard bracket?
Anyone have any ideas how I will feed the sky+ through?
advice, install
