Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Old 05-02-2006, 6:57 PM   #1 (permalink)
ash
ash's Avatar
Thanks: Gave 630, Got 420
Rising the floor for sofas, how do you do it?
Hope no one is confused about the title, I just want to know how people make like boxes that you put your sofa on top. My floor is concrete because its a shed, so any idea how I can do it?
I dont mind if its portable, should I make a box and put weights in it?
Batman Begins at IMAX!
ash is offline   Reply With Quote
Old 05-02-2006, 7:06 PM   #2 (permalink)
Miniholic's Avatar
Thanks: Gave 516, Got 386
I think most peope just make a wooden platform. In your case you could quite easily anchor it to the floor if its just solid concrete.
Check out the gallery in this post, there a some good construction pics in there.
http://www.avforums.com/forums/showp...&postcount=497
Sony HW10, Denon 3910, 3806. Toshiba HD-EP30. Pioneer CLD-D925, TF100GB. Panasonic BD35, NS830 VCR.
Carada Criterion 92" screen. PS2. Wii. B&W 602.5, LCR60, 601s3, 600s3 & ASW675. Harmony 1000.
My DVD’s The Miniplex Skip to the end...
Miniholic is offline   Reply With Quote
ashmufc (05-02-2006)
Old 05-02-2006, 7:26 PM   #3 (permalink)
ash
ash's Avatar
Mm.... I'm no DIY man.
Mine wont need to be that big. Do you really need those many bars going along.
I was thinking more like, making a base (wood) and then making the edges coming up, and then filling it up with cement(or whatever) and then putting another wooden piece on top.
Is that the best cheapest method? What type of wood do you recomend, MDF?
Old 05-02-2006, 7:32 PM   #4 (permalink)
shahedz's Avatar
Thanks: Gave 789, Got 425
i would leave a 1 ft gap between the bars( i think they would be called joists here) , i wouldnt use concrete, messy, and would be a nightmare to dismantle if you wanted rid of it
Linn Kolektor pre amp & LK140 amp,Genki,Sony MD MDS JE510,Sonos ZP80 + CR100,Ariston RD-40 turntable,TDL RTL3 ,Samsung32R87, Yamaha YSP-1000,Panasonic PT-AX100E projector,Toshiba HD-E1 ,Sky HD, PS3,Harmony 885
shahedz is offline   Reply With Quote
Old 05-02-2006, 7:58 PM   #5 (permalink)
ash
ash's Avatar
Any other ideas apart from concrete? I was thinking of some heavy weights, maybe an amp lOL!
Old 05-02-2006, 8:57 PM   #6 (permalink)
shahedz's Avatar
paving slabs ontop of each other until the desired height is reached? and area covered?
Old 05-02-2006, 9:00 PM   #7 (permalink)
ash
ash's Avatar
Nice idea, what do you mean slabs?
Old 05-02-2006, 10:22 PM   #8 (permalink)
Thanks: Gave 4, Got 32
If its just to raise the sofa itself then build one like in that pic further up , i'd make the joists around 400mm centres , it should be apiece of shizzle to build!
Give me the dimensions and ill knock it up in an hour lolol
In all fairness , even someone with basic diy skills should be able to build something like that
Jon
Jon Boy is offline   Reply With Quote
Old 05-02-2006, 10:28 PM   #9 (permalink)
shahedz's Avatar
if youre only raising a small sofa etc, just buy some paving slabs (pavement slabs) from home base, B&Q etc and put them on top of each other, or you can get some breeze blocks and get some wood and screw it into the sides of the blocks so they are all held in postion and dont move, literally line the breeze blocks up side by side and screw a baton along the sides into each screw to hold the blocks in place, if you do it tightly it shouldnt move, woud be really simple as well
Old 05-02-2006, 10:30 PM   #10 (permalink)
But then surely that would make it uncomfortable as your legs would just dangle over the edge of the sofa, plus it would make it more tricky for shorter people to get on the sofa?
Old 05-02-2006, 10:38 PM   #11 (permalink)
shahedz's Avatar
he doesnt have to have it exactly the same size as the sofa, he can have it protuding by 10 cm or 50cm what ever he wants so legs do not dangle over and people can step up , i dont know his exact dimensons, mearly giving a solution to his problem
Old 06-02-2006, 4:40 PM   #12 (permalink)
ash
ash's Avatar
True, I would wnat a base for putting my feet on.
Old 06-02-2006, 7:10 PM   #13 (permalink)
Measure the length and width of your sofa and decide how much of the platform you want sticking out. The get the car warmed up and pop down to b&Q and buy some 4"x2" / 5x2" / 6"x2" planed timber ( ill hazard a guess that youll need 6 lengths in total just to be sure.
Also whilst your down there grab a box of 3" or 4" nails.
Take the overall length of the platform that you previously measured and cut two of your lengths of timer to this size.(1)
Then take the width you measured earlier , subtract 4" from this measurement and cut those.(2)
Now place the longer timbers(1) on the ground and fix the shorter timbers(2) in between them at either end.
Measure the length inside the frame and cut the rest of the timbers(3)
With the left over timbers cut some noggins to go inbetween the timbers just to strengthen it up a bit(4)
Fix it all together using your nails by fixing into the corners!
Cover the top of it with sometounge and grooved ply boards , i think they do them in loft packs designed for the floor of your loft or alternatively you could you mdf.
Then you can carpet it or finish it how ever you want!
Heres a pic i did in ms paint which may help with the numbers from the description!
Now get off your lazy backside and build it lolol
Keep us posted matey
Jon
ashmufc (06-02-2006)
Old 06-02-2006, 7:39 PM   #14 (permalink)
ash
ash's Avatar
Cool, thats a great post.
So how high will the base be then?
And will the be heavy enough so it doesnt move? Well actually, a moveable one would be cool
And covering the top, say I choose MDF, I just screw it in.
Old 06-02-2006, 7:53 PM   #15 (permalink)
Miniholic's Avatar
You can make it as high as you want, materials permitting. The sizes Jon Boy states 4"x2" / 5x2" / 6"x2" planed timber will give you a platform 4, 5 or 6 inches high (plus the thickness of the board used on top).
You then just need to buy some sheets of MDF or ply for the flooring. I'd allow for an overhang of around 1/2" to 1" so that you can wrap the carpet round, and fix it from underneath. For added bling some people even put rope lighting under them to illuminate the step. Depending upon taste this gives one of two looks, cool or chav.
EDIT: Knew I'd missed something. The weight of the wood and the sofa should keep it from moving. And the MDF can just be fixed with countersunk screws into the joists.
floor, rising, sofas
