15-10-2005, 10:50 PM
#1 (permalink)
| | Member
Thanks: Gave 30, Got 38 | My little cellar's story begins.....
Hi all,
After months of money raising and planning, the work on my cellar conversion begins. The room size is 14.5ft x 8ft. A window has already been put in (not shown in the picture) and the electrics and plumbing are being done. The waterproofing (tanking) company are due to start work at the end of October/beginning of november, after which all that will need doing will be the decorating and a wooden floor being laid.
The AV gubbins will be situated where the gas and electric meters are, the tanking company are going to build a false wall to cover up the meters. The back of the room houses a door which leads to a 10 x 8 room which is going to be used for storage.
I have started sound proofing the ceiling with Acoustic quilt and mineral wool slabs from http://www.customaudiodesigns.co.uk/, unfortunately due to the height of the room I cant sound proof it properly, with a bar system which stops the bass travelling.
As our current TV has developed a fault I am going to have to buy a new 37" LCD (its a tough life!!). My current setup of a Sony STDB-940 AV receiver, Mission speakers and a Yamaha sub will make up the rest, no new additions here :-(.....sorry I tell a lie....an XBOX 360 will grace the room......if there is any left!!
I hope to have the room finished by mid-end november. I'll update pics and news when it happens!
16-10-2005, 7:48 AM
#2 (permalink)
| | Moderator
Thanks: Gave 99, Got 398 | Quote: |
| Good stuff
I will watch this thread with fond memories of when i had my cellar converted last year |
17-10-2005, 2:51 PM
#3 (permalink)
| | Member
Thanks: Gave 30, Got 38 | Quote: |
Originally Posted by inzaman Good stuff
I will watch this thread with fond memories of when i had my cellar converted last year  | kewl....I can pick your brains for advice!!!
18-10-2005, 7:48 AM
#4 (permalink)
| | Moderator
| You sure can, there are also plenty of other member who will give you sound advice on the various areas as you progress |
19-10-2005, 10:01 AM
#5 (permalink)
| | Member
Anybody got any ideas about running cabling...mainly rear speaker cables, so that you can change the cable easliy if needed ? The solution will need to fit behind plasterboard or I could run it through the jiosts....any suggestions appreciated.
Thanks.
19-10-2005, 10:51 AM
#6 (permalink)
| | Member
Thanks: Gave 28, Got 24 |
I'd be interested in ideas on speaker cable as well. I can hide the fronts ok, it's the surrounds.
At the moment it looks like they'll simply be painted the same colour as the wall but that's about it. I have 3 surround speakers mounted on brick walls and one on a plasterboard wall (the type with the cardboard box sections inside).
__________________ Sanyo Z3 pj, Panasonic TH-42PZ80B, Denon 2805 AVR, AE Aegis Evo3B 7.1, Pioneer DV-575A & DV-600AV, Sony RDR-HX510 DVD Recorder, Sony Freeview VTX-D800U, Humax Foxsat-HD Freesat.
HTPC: GA-MA78G-DS3H/Athlon 4850e/MSI N210-MD512H gfx |
20-10-2005, 3:27 PM
#7 (permalink)
| | Prominent Member
Thanks: Gave 860, Got 469 | Quote: |
Originally Posted by HCK Anybody got any ideas about running cabling...mainly rear speaker cables, so that you can change the cable easliy if needed ? The solution will need to fit behind plasterboard or I could run it through the jiosts....any suggestions appreciated.
Thanks. | how about running the cable through pipes or trunking , and then when you want to upgrade the cable you disconnect the old cable from the amp , tie the new cable to the end of it and just pull it through?
__________________ Linn Kolektor pre amp & LK140 amp,Genki,Sony MD MDS JE510,Sonos ZP80 + CR100,Ariston RD-40 turntable,TDL RTL3 ,Samsung32R87, Yamaha YSP-1000,Panasonic PT-AX100E projector,Toshiba HD-E1 ,Sky HD, PS3,Harmony 885 |
20-10-2005, 4:08 PM
#8 (permalink)
| | Senior Member
Thanks: Gave 66, Got 86 | Quote: |
Thanks. | I used 40mm plastic waste pipe as can be seen here as it exits the plasterboard ( the pipes are run within the wall as per the writing that can be seen on the plasterboard.
The darker cables are the video cables, one is HDMI - HDMI and other is SVideo - SVideo, the two white cables are actually telephone wire for use as pull-throughs if I require to put any other cables within the wall.
The 40mm pipe from Homebase isn't as thick in contruction as the stuff I got from the plumbing supplies place, this was only really an issue when I came to join the 2 pieces together with a glued joint as the cheap stuff from Homebase wouldn't glue together as it had a slightly smaller outer diameter than the joints so bear this in mind, it might be half the price but its not as easy to join.
Thing is you need to use glued joints as the pushover ones are too big for the plasterboard strapping which is usually 50mm.
Don't know if this will help, but it worked for me.
Cheers,
Mike.
__________________ Canon 50D - Canon 70-200 F4L - Canon 400mm F5.6L - Tamrac Expedition 8x - Manfrotto 055CLB Tripod - Manfrotto 393 Head - Manfrotto 681B Monopod - Ergorest Multipod |
20-10-2005, 9:23 PM
#9 (permalink)
| | Member
thanks for the ideas guys.....I had simliar ideas but im just trying to work out the practicalities of doing it!!
22-10-2005, 11:25 AM
#10 (permalink)
| | Senior Member
Thanks: Gave 32, Got 54 |
oh this brings back memories.
good luck, be nice to see the end product
22-10-2005, 12:45 PM
#11 (permalink)
| | Senior Member
Thanks: Gave 31, Got 30 |
I had 2 rooms done at the same time as inzaman and ive still not painted the second room cause i either spend my time on here or in the cinema room.
To be honest it depends on how your tanking the walls if your having it rendered then pipes is the way to go. If your using a stud wall and membrane system you should just be able to run the cable in the space behind the stud wall.
23-10-2005, 5:20 PM
#12 (permalink)
| | Member
it will dry lining used...but i think im gonna run the cable in the joists as close as I can to the wall so it can drop behind the plasterboard. I will update shortly with a few pics as the window has been put in and the plumbing has been moved over over to one side of the wall
24-10-2005, 10:33 PM
#13 (permalink)
| | Senior Member
Thanks: Gave 2, Got 14 |
Assuming it's not an overley big cable you could use 20mm PVC conduit and form the bends with a bending spring. The advantage being that you will be able to push a draw tape straight through which you will have trouble with if you use manufactured bends even on the larger truncking. If you use manufactured bends you will need to feed and leave a draw wire in which if it comes off while your drawing the cable in you will be (excuse the term) knackered.
20mm PVC is cheap and easy to work with. If you decided to go this way I could lend you a bending spring assuming I didn't need it at work and could possible sort you some fittings out if we have them on site. I pass Ossett most days on the motorway.
Would be interested in here how you go on with the tanking as I'm looking into doing our cellars. When it rains one of the rooms floods and like today I spend an hour sucking up the water after work
TTFN! Gaming Tag m0cea |
24-10-2005, 11:26 PM
#14 (permalink)
| | Member
Originally Posted by TooManyHobbies Assuming it's not an overley big cable you could use 20mm PVC conduit and form the bends with a bending spring. The advantage being that you will be able to push a draw tape straight through which you will have trouble with if you use manufactured bends even on the larger truncking. If you use manufactured bends you will need to feed and leave a draw wire in which if it comes off while your drawing the cable in you will be (excuse the term) knackered.
Would be interested in here how you go on with the tanking as I'm looking into doing our cellars. When it rains one of the rooms floods and like today I spend an hour sucking up the water after work  | Thanks for the offer, I will probably take you up on that!! When the tanking has been put in you are welcome to pop by to see the work. It sound like you will need what im having done, which is a pump and a sump put in, along with drainage channels. We have water that trickles in at the back of the cellar (the storage part  )....but the rest of the cellar is fine.
25-10-2005, 7:56 AM
#15 (permalink)
| | Moderator
| I had to use the membrane system with a sump and pump for mine as it is quite damp, especially when it rains. Lucky i do have a pump as we have has a lot or rain the past few nights and i have seen it working in the run off outside.
