Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
How to hide cables in walls / ceilings Rob_Quads Home Cinema DIY 3 20-04-2005 10:21 AM
Good Cables (Not Overpriced Monster) jaycook Interconnects, Speaker Cables and Switches 3 04-04-2005 5:08 PM
Embedding Cables into Walls steve 111 Plasma Televisions 7 27-06-2004 12:34 AM
What cables should I embed in walls?? chrissles Interconnects, Speaker Cables and Switches 8 02-10-2003 5:27 PM
Fixing Plasmas/hiding cables on dot and dab walls jaminho Plasma Televisions 7 19-09-2003 3:25 PM
Old 01-10-2005, 4:50 PM   #1 (permalink)
Thanks: Gave 5, Got 4
Cables exiting walls - how would you do it?
I have to chase the walls for the cables to my wall mounted pwd7. what concerns me is how i exit the walls at each end of the run?
i guess plugs/sockets would be the cleanest solution but i haven't seen them readily available?
the option i'm thinking of at the mo is using the faceplates with "brushes" to tidy things up, but you still end up with tons of cable hanging out of the wall!
dickst3 is offline   Reply With Quote
Old 02-10-2005, 1:23 PM   #2 (permalink)
Thanks: Gave 7, Got 11
I use these, avaliable in single and double gang:
http://www.home-networking-online.co...eplate_50.html
jefff is offline   Reply With Quote
Old 03-10-2005, 6:07 AM   #3 (permalink)
Or you could terminate each cable run behind the wall and use phono connectors..
Can any of the audiophiles confirm this is ok. (gold plated), then have a short cable run from the socket to speaker.
http://cpc.farnell.com/jsp/endecaSea...e&No=0#results
If not here are a couple of alternatives
http://cpc.farnell.com/jsp/endecaSea...=AV06731&N=411
http://cpc.farnell.com/jsp/endecaSea...=AP00003&N=411
http://cpc.farnell.com/jsp/endecaSea...=LS00805&N=411
http://cpc.farnell.com/jsp/endecaSea...=LS00806&N=411
or the main search result with all the connectors
http://cpc.farnell.com/jsp/endecaSea...&Ntk=gensearch
Mike
What happens when you exceed the maximum or go over the limit... do they just change the limit.....
dupontin is offline   Reply With Quote
Old 03-10-2005, 6:40 AM   #4 (permalink)
Mike,
what about this?
http://cpc.farnell.com/jsp/endecaSea...KU=AV12254&N=0
that would look very tidy. but would i be able to shorten the cables? i only have about 1 metre to the screen.
i only need vga and power to the screen, plus two sets of speaker cables. i will but a fused spur behind the screen so that will take care of the power.
thanks guys
Old 03-10-2005, 7:41 AM   #5 (permalink)
this looks promising
http://www.euronetwork.co.uk/acatalog/SVGA_Cables.html
Old 03-10-2005, 3:13 PM   #6 (permalink)
cheeky
Posts: n/a
jefff,
these gang brush faceplates are a great solution. do you know if a plug will fit through these?
creating too many joins will surely create signal loss...does anyone know if this is has been proven????
Old 05-10-2005, 4:38 PM   #7 (permalink)
Cheeky,
I have a couple of the double gang brush face plates, one behind the plasma, and the other on the skirting board. Its a tight squeeze but you can get a standard size 3 pin plug through the brushes.
Old 05-10-2005, 9:03 PM   #8 (permalink)
cheeky
Posts: n/a
Thanks - sound worth while getting a couple then. These are the best thing I've seen so far.
Old 06-10-2005, 6:36 AM   #9 (permalink)
just got four single gang - doubles were out of stock
they are ok, and should provide a tidy solution. i will probably run some kind of trunking so that i can add/remove cables in future.
come on you blues
42PWD7, (a very cheap) Sony DVD through Sky box and JS RGB into VGA, sound provided by Teac Ref 500 amp and a pair of Mission speakers. All controlled via a Harmony 655 (not any more, it bit the dust )
cables, exiting, walls
