Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Samsung LE32R41BDX - My impressions (56k warning!) Munkey Boy Xbox 360 223 24-05-2006 11:36 AM
Wall Mounting ESAUJLA Flat Screen TV Brackets and Mounts 1 10-01-2005 1:10 PM
lg rz42px11 wall mounting jogo Flat Screen TV Brackets and Mounts 2 22-12-2004 4:26 PM
Wall Mounting Surr. Speakers chubbyandy Speakers 3 22-12-2004 3:40 PM
UT 2004 Demo Stellavision PC Games 22 05-04-2004 2:18 PM
Old 29-09-2005, 7:53 AM   #1 (permalink)
GB_WGC_2005
Posts: n/a
Wall mounting my Samsung LE32R41BDX
Can anyone advise whether I should do this myself.
Basically I have a solid brick wall with an understairs cupboard behind it. I have a cabinet built in to the same wall (below where the TV is to go) which will house my DVD player and video. What I was planning to do was feed the cables through the wall into the cupboard and then into the back of the devices in the cabinet. Is this a good idea or should I be chasing the cables in? I haven't got a clue whether to get the professionals in!
If anyone can offer advice on how to route the cables, what materials to use, etc, that would be very helpful.
Old 29-09-2005, 2:58 PM   #2 (permalink)
IronGiant's Avatar
Thanks: Gave 582, Got 1,554
No, sounds like a grand plan to me, much simpler than chasing cables in and much easier to change anything. If you want to be perfectionist you could line the hole(s) with a polythene pipe to prevent cable chaffing but I don't think it's strictly necessary.
dave
IronGiant is offline   Reply With Quote
Old 29-09-2005, 3:52 PM   #3 (permalink)
GB_WGC_2005
Posts: n/a
cheers Dave, maybe I'll post some photos of my handywork - it might make a good case study
Old 29-09-2005, 6:20 PM   #4 (permalink)
GB_WGC_2005
Posts: n/a
A guy at work was mentioning using phono to SCART converter / cables rather than going SCART to SCART from my VCR to TV and DVD to TV. He says it will mean not having to make such a big hole in the wall for fat SCART cables. Does anyone know what exactly I'd need to achieve this, or am I better off going SCART to SCART for both devices?? It's all Greek to me..
Do I need a converter and a cable? If anyone has any good links, those would be appreciated..
Thanks again
Old 01-10-2005, 3:20 PM   #5 (permalink)
IronGiant's Avatar
It depends what picture you're looking at Composite, s-video or RGB, going to phonos and scart convertors means you can only use composite unless you use an s-video lead. If you want to retain SCART (and I would advise you to, unless you know you are watching a composite picture), find a SCART lead where you can easily remove the outer casing. This will decrease the size of hole to cut but retain maximum connectivity.
Dave
le32r41bdx, mounting, samsung, wall
