Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 07-09-2005, 4:20 PM   #1 (permalink)
kid of the kop
Posts: n/a
Smile soundproofing a ceiling
i need to soundproof my ceiling i was thinking of using 2*2 studs inch away from the ceiling stuff it with rockwool then use 1 layer of 12m plasterboard then 1 layer of 9.5m plasterboard do you think this will work
Old 08-09-2005, 12:34 PM   #2 (permalink)
Thanks: Gave 2, Got 2
Think that might be too heavy? What will stop it from sagging in the middle?
Pioneer PDP434, Pioneer DV-575A, Sky+, HTPC, Yamaha AX750SE, Acoustic Energy EVO 3Bs, PSP, Xbox 360
Jimbo73 is offline   Reply With Quote
Old 10-09-2005, 10:41 AM   #3 (permalink)
Conspicuous Member
Gary Lightfoot's Avatar
Thanks: Gave 12, Got 377
What would work better, is to remove the existing ceiling, install new timbers that are the same dimension as the existing ones (or the same as those for the bedroom ceiling which would also be the floor for the loft - say 4 x 2 instead of 6 x 2 for example) so that they fit in between (but not touching) the existing timbers. This would give you the strength to hold up the new plasterboard without sagging and be more effective for soundproofing. It also means you don't lower the ceiling any more than you have to as only 2ins of the new beams has to be protruding from the existing beams.
Finish with Rockwool insulation and two layers of 1/2" plasterboard or one 1/2" and another 5/8ths". Seal all edges with silican sealant or similar to ensure there are no air gaps for sound to travel through. Fit a thick rubber underlay material upstairs before laying the carpet. It might help to seall all the gaps in the upstairs floorboards as well as the edges by the skirting while you have the carpet up.
Gary.
Gary Lightfoot is offline   Reply With Quote
Old 12-09-2005, 1:51 PM   #4 (permalink)
ancientgeek
Posts: n/a
There are of course commercial systems made for sound insulation when refurbishing. Important features for what you do:
1. airtight seal from floor above
2. mechanically isolate new ceiling from floor above (somebody makes sort of springy hangers to support the ceiling without transmitting vibration).
3. mass (more mass is better).
ceiling, soundproofing
