Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 29-08-2005, 4:23 PM   #1 (permalink)
Speaker Cable
Hi everyone
The garage conversion is underway, plasterboard to go on in the next couple of days. The builder hasnt left enough room behind the studding to run any conduit (I did ask, but I think he got carried away!!) So I need to run speaker cable, can anyone advise?? I did read some threads about using 3 lengths of cat5 network cable, per speaker, platted. I havnt enough cable to triple each length up, has anyone used just a single run of cat5 cable per speaker, any thoughts welcome.
Many thanks
John
jhaworth is offline   Reply With Quote
Old 29-08-2005, 7:22 PM   #2 (permalink)
Thanks: Gave 7, Got 15
Are you saying the space is only wide enough for network cable?
After reading threads on here, I used mains cable (twin and earth) for all the hidden speaker cabling
woody67 is offline   Reply With Quote
Old 08-09-2005, 1:14 PM   #3 (permalink)
Thanks: Gave 4, Got 5
I've used a single cat 5 for each speaker in my setup because it was all I had to hand and to be honest it sounds fine.
Would love to get into the plating thing but for the amount of power my speakers use and the quality aspect, I'll stick with CAT5 and spend the rest of the cash on decent video interconnects.
Yamaha RVX-457, NSP-110, Pioneer 434HD, XBOX360 via component, PS3 on HDMI, Sky+, RTI T2C (lounge) T2+(bedroom) T1(kids) Remotes with RP1 and RP6
spickee is offline   Reply With Quote
cable, speaker
