Hi I'm both new here and to home cimema - great forum!
I want to create a home cinema setup in my front room that will only be used for movies etc and will be as unobtrusive as poss. I am limited by the shape of my room and furniture and have come up with the following proposal;
The screen size will be roughly 2000mm x 1200mm and this fits with the distance to the projector and the projector I've got my eye on (Benq PE5120). The projector will be mounted on the ceiling.
My main concern is the viewing position and my dining table. As you can see the sofas face each other so to view the screen in the bay you will have to sit sideways or put your feet up. Is this bad?
The screen is not obscured by the dining table or chair backs but will they draw the eye and detract from the viewing?
Finally, the distance from the screen for the viewer will be appx 5500mm about 2000mm behind the projector, is this too far away?
Gary
