Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Sherlock Holmes Blu-ray ReviewClash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray Review
Cirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray Review
Old 21-03-2005, 9:01 AM   #1 (permalink)
jtf
Thanks: Gave 3, Got 3
best way to connect a wall mounted plasma
i am soon going to be wall mounting my pw7 and a little confused as to which would be the best solution to wire up the power. is it a case of exteding the power cable and then plugging it into the mains or is there a better solution. i have a mains socket below where the plasma is going to be mounted, could i wire it up directly to the mains?
jtf is offline   Reply With Quote
connect, mounted, plasma, wall
Copyright © 2000-2010 M2N E. & O. E.
