Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 18-03-2005, 7:27 PM   #1 (permalink)
Thanks: Gave 55, Got 30
Decorating a Home Cinema
Hi people
I am just realy after ides for a good looking cheap way to decorate a home cinema.
I thought of maybe a DTS or Dolby surround sound plaque??
Also I was thinking of getting classic film posters, the ones that will go down in history like Casablanca, Blade runner, Star wars
Any idea would be apprecieated.
dave1de is offline   Reply With Quote
Old 19-03-2005, 7:12 PM   #2 (permalink)
Sly
Sly's Avatar
Thanks: Gave 41, Got 17
have a search around this forum and others for pictures of what others have done.
also check out home cinema gallery sites like http://www.vbstudios.utvinternet.com/newhome.htm
these always have some good ideas to inspire you , then when your finished you can post your pictures here for us to have a look at!!
kit:sanyo z4,sammy lcd tv,Onkyo 905,Panasonc bd60,M&K XENON series with tripole surrounds,BK xls200,360 elite with HD drive.
Sly is offline   Reply With Quote
Old 19-03-2005, 7:18 PM   #3 (permalink)
Johnny Thunder's Avatar
Thanks: Gave 236, Got 148
See if you can get some inspiration from Plasmas out for the lads..........
Plenty to look at....
Johnny Thunder is offline   Reply With Quote
Old 20-03-2005, 12:47 PM   #4 (permalink)
Cheers for the idea guys.
Yep, i sure will psot pics when its all done. The sound system and room have all been set up ready, all I need now is the projector which I have orderd and a screen. Should all be done in about 2 weeks :-D
Old 25-03-2005, 8:57 AM   #5 (permalink)
gaz
Thanks: Gave 3, Got 0
Originally Posted by dave1de
Hi people
you could try theese i not sure if they ship to uk also if you check out the avs forum there are some you can print off and frame i did this although they spell theatre "theater"
http://www.codebelow.com/underg.html
gaz is offline   Reply With Quote
Old 25-03-2005, 4:55 PM   #6 (permalink)
inzaman's Avatar
Thanks: Gave 91, Got 365
dave1de, if you are getting a pj you could always check out the let see yours post on the projector forum for some very good ideas, there is also some ideas on diy projector ceiling mounts if you wish to keep the cost down.
inzaman is offline   Reply With Quote
Old 25-03-2005, 7:17 PM   #7 (permalink)
Mr Bump's Avatar
Thanks: Gave 2, Got 5
In my experiance, you want to avoid having anything reflective on the side or end walls, as it just reflects light from the screen and is a distraction. By all means put up a poster on the wall behind you, but otherwise avoid, unless you can find some really low reflective material to mount them in.
New Toy Room
Mr Bump is offline   Reply With Quote
Old 25-03-2005, 8:21 PM   #8 (permalink)
Yeah mr bump i never thought of it reflecting on the side walls, the screen I am getting is manual, so it could pull down over some posters. I will see when its all set up. I am aiming for it to be complete next saturday, and will post pics in the gallery then.
Old 28-03-2005, 9:22 AM   #9 (permalink)
Well, after a trip into penco (an artist place with movie prints, posters, autographs) in my town I got some very nice 20" posters which should be easy to frame.
Also got the screen (which is a blackout blind) from focus, which will do the job at a great price of £50
cinema, decorating, home
