10-03-2005, 12:28 PM
#1 (permalink)
| | Member
Thanks: Gave 0, Got 1 | Chasing Walls
Hi Guy,
I plan to chisel a 40mm by 40mm channel in a load barring wall, The Channel will be 125mm long & running diagonally from just off centre to the bottom left of the wall,
This is to fit a 32mm Diameter tubing to enable me to change cable if I wish to in the future.
Can someone tell me if this channel will effect the stablility of the walls?
Thanks in Advance
Dan
Pan TH-42PE30, Sony GXD500, Sky+, Aego P5
10-03-2005, 11:08 PM
#2 (permalink)
| | Member
Anyone??
I hope to start this at the weekend
11-03-2005, 1:19 AM
#3 (permalink)
| | Member
Thanks: Gave 7, Got 17 |
Go for it!
At 125mm long it doesn't really matter. I've just had a new extension/HT room built and the dividing wall which is by the way is Very stressed  has had a 175mm ish x 125mm lutron back box along with many more cable chases cut into it with the permission of the local distric surveyer.
At the size you mention, have no fear!!!! |
11-03-2005, 1:31 AM
#4 (permalink)
| | Member
Thanks for you advice, will go for it!!
Dan
11-03-2005, 9:53 AM
#5 (permalink)
| | Super Moderator
Thanks: Gave 961, Got 724 |
You might want to drill a series of holes to more easily enable the knocking out any masonry and give you a cleaner line (your chisel just 'joins up the dots', in effect). An SDS drill would do that in seconds.
Mike.
11-03-2005, 9:55 AM
#6 (permalink)
| | Member
Thanks: Gave 0, Got 2 |
Just a point, although there's nothing to stop you, you shouldn't really channel cables in diagonally. This makes it very very hard for future residents to trace wires. You should go either directly up or down or left or right from where the wires go in, then turn a right angle and run to where the wires come out again.
...if that makes sense.
Darren
11-03-2005, 11:34 AM
#7 (permalink)
| | Member
Thanks for your advice,
The cables that are running diagonally are only the singnal cables, Power cables are running as they should, Straight up in separate conduit with capping protecting them from anyone drilling into them.
I was going to run the signal cables diagonally because it would be easier ti pull the cables though or to add new ones, I was also going to draw a plan up and inform any future occupant of where the cables run, do you think this is acceptable, I think the cables I have are not long enough for the other way. I may also remove the cables when we move.
Dann
11-03-2005, 11:55 AM
#8 (permalink)
| | Member
Its mainly to protect against people accidentally drilling through power cables so you should be OK.
If you put anything in writing or draw up a plan to give to the next owners, make sure you mention that you did these mods before 2005 because otherwise you might compromise yourself under the new rediculous laws banning DIY electrics.
Darren
11-03-2005, 12:25 PM
#9 (permalink)
| | Member
The power cable is just for the TV & I wll be using the original that came with the TV, This cable will pass through a Flex outlet, to connect to a socket, Because its the original I will be removing it when we move.
I am aware about the changes in the IEE Regs, & have the listed changes at work, I will double check but I think adding additional socket does not need certification as long as it is not in the kitchen or bathroom, I work with a few sparkies so I can get their advice if needed.
Basically most of the work will be removed when we go unless the next buyers request that it stays.
As long as 125mm x 40mm channel is ok i will start this weekend.
Thanks for all the advice
Dann
11-03-2005, 10:39 PM
#10 (permalink)
| | Moderator
Thanks: Gave 581, Got 1,554 |
125mm = 5 inches (or thereabouts), 40x40x125mm sounds like a cutout for a double socket patress box not a channel up the wall to pull cables through, are you sure you didn't mean 125cm for the length of the channel (ie about 4 feet). I'd definately be reticent about cutting a 40x40mm channel for 125 cm diagonally across a structural wall. Of course if you meant 125mm ignore what i just said.
Dave
12-03-2005, 3:36 PM
#11 (permalink)
| | Member
Hi Regmarch,
thanks fro spotting the mistake, I did mean 125cm. Do you think this would be a problem then?
12-03-2005, 4:04 PM
#12 (permalink)
| | Member
Just to add from the previous post.
Now that I have posted the correct measurments for the channel (125cm x 40mm x 40mm). SORRY EVERYONE.
If this is now thought of too deep, How deep do you recommend I go? I was hoping to be able to remove the cables by putting them In this 32mm Pipe, but If this is too deep I may as well cut a smaller channel & leave them I there.
what do you think?
12-03-2005, 4:38 PM
#13 (permalink)
| | Member
Whats the wall made from and how thick is it?
12-03-2005, 4:48 PM
#14 (permalink)
| | Member
The wall is 130mm thick & I think it is solid brick, Built in 1967 if that helps.
Looking at it again I think I have a better way of routing the pipe:
1 20mm Dia conduit for the power cable running striaght up for 900mm, 25mm deep.
1 35mm Dia Waste pipe for the rest of the cables running striaght up for 900mm, 40mm deep.
These channels would be running 20mm apart & both will have switch boxes at either end.
Sorry to keep changing the original question.
What do you think?
12-03-2005, 7:43 PM
#15 (permalink)
| | Member
Thanks: Gave 7, Got 15 |
At 130mm thick, your wall is likely to be a 100 or 110 wide brick, with plaster each side.
IIRC, recommended chases are max 1/5 (ie 20mm) of the structural wall (ie brick). But it does depend on the location of the chase and if the wall is loadbearing.
32 conduit seems too wide for this purpose. Can't you use 20 or 25mm - eg standard plastic overflow pipe?
