Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Notices
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 09-03-2005, 9:53 PM   #1 (permalink)
Thanks: Gave 4, Got 41
The quotes in and ....
... its £3800!!!!!
Let me explain.
My dream of having a home cinema in our adjoining garage was coming to fruit as the Mrs had eventually agreed to it (on the condition that the room also housed some toy's for the little ones and she gets to call it a kids play room ). Anyway, I got a builder friend around to do a quote for the following :-
  • Build false wall in front of garage door in case we want to turn it back to a garage
  • Cut a door way from the kitchen into the garage
  • Brick up an existing doorway to the garage and put a window in some of the hole it leaves
  • Render the walls and ultimately plaster them
  • Plaster board the ceiling and skim it
No electrical/wiring or plumbing work just the above.
Is it just me or does £3800 sound a little expensive. Maybe I'm just being a tight arse but I'm considering doing it myself (apart from the cutting of the door, way too scarey!).
Should I get another quote in? Is it going to be around the same value?
Baloo is offline   Reply With Quote
Old 09-03-2005, 10:32 PM   #2 (permalink)
stripe's Avatar
Thanks: Gave 14, Got 16
Sounds very expensive to me, I'm hoping to get the same done with electrics plumming and a window in for under £3K.
Michael
stripe is offline   Reply With Quote
Old 10-03-2005, 9:08 AM   #3 (permalink)
The more I think about it the more I'm coming to the decision to do it myself. I'm pretty handy but its just finding the time. With a little one around my feet and the wife pregnant, time to do it could be hard. But if it saves me ££££'s its got to be worth it.
Old 10-03-2005, 1:32 PM   #4 (permalink)
Johnny Thunder's Avatar
Thanks: Gave 236, Got 148
You have all the help and advice you need, right here.............
Johnny Thunder is offline   Reply With Quote
Old 10-03-2005, 2:56 PM   #5 (permalink)
Thanks, I'm sure I'll be asking a million more questions as things progress.
Old 10-03-2005, 5:08 PM   #6 (permalink)
hatcher's Avatar
Originally Posted by Baloo
... its £3800!!!!!
Let me explain.
Just wanted to talk on this thread too...
Builders prices are very variable. With the people I chose the build phase on mine - that's empty garage to room with plastered walls incl. electrics and a new larger dg window - was ~£5k.
The builder and plasterer were very good but the project management sucked causing it to drag out over a long time.
They also did the porch (up to a plasterboard/timber finish) and that came to £2,800 - £600 of that was just the roof!
But if you think that's bad I had numerous other quotes from £7k-9k for the garage and £14k-£18 for the garage with a brick built linkway.
Seeing what they did, it wasn't that difficult (apart from the floor screeding which could be done as timber joists) so if you feel confident go for it.
I agree cutting a doorway through an outer wall is far to scarey
Cheers,
Hatch
Home Cinema Pages
hatcher is offline   Reply With Quote
Old 11-03-2005, 8:32 AM   #7 (permalink)
Thanks: Gave 1, Got 7
Baloo - go for it, you said you are handy around the house. Its not that hard, any tech advise and some one here has probably already done it. Even the door might be worth a shot, just get a door and frame then angle-grid an opening, lintel in then fit frame and job done, & u will feel very proud of that door. If not just a builder in for just that job might cost you about £350 fitted.
Gary
garyc is offline   Reply With Quote
Old 11-03-2005, 8:38 AM   #8 (permalink)
Bristol Pete's Avatar
Thanks: Gave 679, Got 340
I would pay it for the professional work alone and the quality finish it wil hopefully produce.
Cap.
Bristol Pete is offline   Reply With Quote
Old 14-03-2005, 1:17 PM   #9 (permalink)
I've decided to do all of it myself now apart from the cutting the doorway (the Mrs thinks I'll demolish the house if I do ). The first step if buying a shed to house all my garage junk. Wickes seem to be the most reasonable at £150 for a nice sized one so a call to them later on today should sort that out.
Just for reference, the garage is a single one measuring 2.5 meters by 5 meters so pretty standard. I get started on strenghtening the timbers this week by fitting 2x3 noggins in between the strutts. I'll take pictures this week aswell as I know I always like seeing other peoples conversions from the start. Oh, and the timeframe for this conversion is about 2 months, as I'm up against an impending new arrival.
Old 14-03-2005, 9:28 PM   #10 (permalink)
Looking more closely at the garage floor tonight I noticed what appears to be a damp proof membrane underneith. Would I be wise to put another layer on top of the concrete 'just in case' or would that be detrimental in some way.
Also, for insulation, would I need an air vent in the roof of my pitched garage or would some breathable insulation be all I need?
For wall insulation is this the sort of thing I'm looking for? Wall Insulation
And would that be ok for the roof or would I need something like this? Roof Insulation
Old 14-03-2005, 11:40 PM   #11 (permalink)
Thanks: Gave 7, Got 15
Have you got/will you be getting Building Regulation approval? You will need it.
If the garage walls are single brick, then have you considered how the inside surface will stay dry?
The DPC is likely to be above the floor level too, so what is happening here?
You need proper through ventilation in the roof space, even if use that insulation from screwfix
You have to be carefull not to use inappropriate extra DPM to the floor or walls as this could lead to condensation forming and being trapped in the structure.
That quote was too high, and not one I would have expected from a friend. But it is inadvisable to work for friends, so perhaps he did not want the job? I would get two more quotes and talk knowledgably to the builders, so they should give a more realistic quote.
woody67 is offline   Reply With Quote
Old 15-03-2005, 8:52 AM   #12 (permalink)
I will need building reg's for this? I don't think anyone else has needed them or is this because of the new doorway?
From the recommendation of other members I was going to go for insulated stud walls with a small air gap to stop any damp from penetrating. This combined with a layer of foil-backed plasterboard just to be safe and a furthur layer of normal plasterboard to help with the sound proofing.
I didn't see any sign of the damp proof in the brick work but I'll have to have another look.
Ok so what about a couple of air bricks along the outside wall of the garage in the roof space. Would this be an ok idea?
Ok, though this may be the case.
Yeah, I'm beginning to think that too. A friend of mine has just gotten pretty much the same thing done to his garage and the builder charged him £1700. I'd of used the same builder but obviously the trade pays too well as he's jetted off around the world for 3 months on holiday
Old 15-03-2005, 9:23 AM   #13 (permalink)
Baloo,
Are you able to post some pics, just it gives a better idea of your construction questions.
Roof insulation - are u planning to have a sloping ceiling?
Insulation is all about reaching the desired U-value for right element ie. walls .35, ceilings .25 etc. most insulation manu. will have a technical department that can give you advise on their product and your situation. ie. single brick garage wall will require 110mm jablite quilt as example.
Whether you go for building regs approval or not its a good idea i would say to try and meet these targets if poss
Apologies if I just gone down the sucking eggs route for you!!
Gary
Old 15-03-2005, 9:31 AM   #14 (permalink)
Thanks: Gave 18, Got 7
Personally I'd be delighted with a quote of £3800, at the moment the best I've had to convert a double garage is twice that figure +VAT (although that does include replacing the garage doors with brickwork/windows).Mabe I should just buy a 4 grand plasma and be happy with that or is rip off Britain alive and well in sunny Bedfordshire?
stu mcc is offline   Reply With Quote
Old 15-03-2005, 9:39 AM   #15 (permalink)
Originally Posted by garyc
Baloo,
Gary
I was waiting to get a shed to clear the garage out and post some pictures of it empty but I'll get some up as it will make my questions easier to understand.
As for the roof, I was going to insulate it between the raffters and then put a flat ceiling in and insulate that too. Condenstation would be a problem but would the air brick idea work?
Thanks for the insulation details. Its all a bit confusing at the moment as I've gone from expecting a builder to do it all to me trying to list everything that needs doing and purchase the materials in. I wish you could get a nice little checklist of things that need doing and what materials and where to get them from. It would make life a lot easier
quotes
