| Encountered a small problem. HELP!!
Okay so i recently built my ceiling mount for the pj using two 30cm table legs from b&q (the thinner variety) screwed into a piece of mdf with the projector again screwed into the mdf.
The problem is however the legs are not connected to the thread but have a plastic bung inside them which contains the thread.This is not generally a problem as the legs are supposed to be used with the feet on the bottom with the pressure from the top, on the bung. However when the pressure is downwards the legs merely detach from the plastic bung under the load. (sorry for my poor description).
Anyway the solutions i see are to either get a very strong metal/plastic adhesive and hope it holds everything together or secondly attach some hooks to the mdf and again to the joist attached by some high tension rope/nylon/string of some kind (im gathering you can tell i have no clue what im talking about by now)
Do people think this will actually be stable? What is the strongest most durable metal/plastic adhesive? (and where can i get it from?) I have already bought the hooks as a precaution so where could i get some high tension string of some sought to spread the load?
Thanks very much everyone and really appreciate your help as i am really not very confident with the diy and dont want to land up breaking the projector.
Iain
