Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Best IR diode for remote control project? Darren Blake Remote Controls 9 28-07-2004 12:43 PM
Problems with IR keyboard & Remote Trojan Mice, Keyboards, Joysticks and Controllers 0 06-02-2004 2:07 PM
Control RF device from IR remote kentlad Remote Controls 2 25-01-2004 12:02 PM
Start PC with remote control IR command? owenw Computer Systems 8 29-08-2003 1:00 PM
PC IR Remote control from quietpc.com SunnyUK Computer Systems 15 13-07-2003 11:29 AM
Old 20-02-2005, 10:15 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Question IR remote around corners
I'm thinking of getting some IR remote dimmers to replace my standard dimmers controlling the lights in the lounge but they will need to work around a corner
Has anyone else tried this, will it work ? I know (for instance) I can control my tv even when pointing the remote away from the tv and the signal must bounce off the walls, or am i better getting rf dimmers?
Can someone with IR dimmers try operating them by pointing the remote away from the sensor and post some results.
Thanks in advance.
Wookie
wookieman is offline   Reply With Quote
Old 21-02-2005, 11:16 AM   #2 (permalink)
Thanks: Gave 6, Got 20
It all depends on the reflectivity at IR of your wallcoverings and the angles between the units - it's just light after all. I can operate my rear curtains by pointing my remote at the TV screen - it reflects the signal back over my head!
You can get IR repeaters that use a radio link to get around corners, if it does not work in your room.
AVR300+P90/MA GR20+GRC/M5ds/StrataIII,
PT AE3000, Beamax 293cm diag 2.35:1 M-series screen, BDP550, Arcam CD93, Harmony 1000 RC
davehk is offline   Reply With Quote
Old 21-02-2005, 12:11 PM   #3 (permalink)
I've had no problems operating a varilight remote dimmer with a pronto .
The pronto seems to send a fairly strong signal, so you might get different results with different remote controls. A strategically placed mirror or large flat surface (projector screen?) will probably help if you have problems!
Jon.
jsebright is offline   Reply With Quote
Old 21-02-2005, 1:32 PM   #4 (permalink)
Edited - double post!
I used two mirrors to get the signal into the alcove containing my stereo as a student...you had to have good aim though!
Mango Bob is offline   Reply With Quote
corners, remote
