17-02-2005, 4:08 PM
#1 (permalink)
| | Member
Thanks: Gave 2, Got 5 | Wall covering
Hi guys, I'm just about to start a new HC project, having moved house (the room in the sig is no more!). I have a nice big detached double garage and the conversion work starts next Monday. I wanted to ask a question about the walls. I am having the ceiling plastered, but my idea, such as it is, is to have both the floor and the walls carpeted, the idea being that this would give me a reasonable sound field within the room without resorting to ugly sound dampening blocks. Is this a good idea, or am I being daft? I've looked at lots of other room conversions and everyone else seem to have plastered and painted their walls, apart from one guy that covered chipboard in velvet, which seemed like a pain to do. Any advice gratefully received...
17-02-2005, 5:16 PM
#2 (permalink)
| | Member
Join Date: Dec 2003 Location: The Credit Stretch (Olympics 2012 Site, London)
Thanks: Gave 70, Got 27 |
I'd go for floor to ceiling curtains (in a dark colour) if you can afford it. I've seen it in a HC in Guernsey and it looked and sounded fabulous
__________________ Ex-Sunnyvale Amdahl Dinosaur |
17-02-2005, 5:41 PM
#3 (permalink)
| | Member
Yeah, but that means A) the walls will have to be plastered and painted and B) fixing the 4 rear speakers then becomes a problem.
17-02-2005, 6:06 PM
#4 (permalink)
| | Member
Thanks: Gave 0, Got 0 |
There's no reason why you can't carpet (or or carpet tile) the walls as well if you want that look. Some of the forum people have done that. I would still recommend the need to stud the walls out and insulate the garage first and then stick the carpet (tiles) onto that.
I used normal finishes and then had a large rug as a rear wall hanging. Works great to remove the brightness from the room.
Cheers,
Hatch
17-02-2005, 6:37 PM
#5 (permalink)
| | Member
Oh yeah - the room is being properly studded out with soundproof insulation slabs and double thick plasterboard - I was just thinking to put carpet/carpet tiles direct onto the platerboard rather than plastering it.
17-02-2005, 6:53 PM
#6 (permalink)
| | Member
Thanks: Gave 70, Got 27 | Quote: |
Originally Posted by Mr Bump Yeah, but that means A) the walls will have to be plastered and painted and B) fixing the 4 rear speakers then becomes a problem. | The room I saw had curtain floor to ceiling fully all round the whole cinema - you couldn't see the walls at all (so no need for paint or plaster). The speakers were built into fake full height columns in the corners that the curtains butted up to. The centre speaker was built into a small 'stage' below the screen.
17-02-2005, 9:03 PM
#7 (permalink)
| | Guest |
I used fabric panelling, around wooden frames containing Professional acoustic dampening materials... worked a treat, I spent days taking readings into Protools and adjusting the heights and thicknesses of the panels before covering but you don't have to go to those lengths!
Have a look Here it's really not that hard
17-02-2005, 9:58 PM
#8 (permalink)
| | Moderator
Thanks: Gave 91, Got 365 |
You will be okay with carpet on the walls, as stated above a few forum members have done this.
Doinks idea also seems really good and looks pretty slick as well, i might do that to my back wall if needed.
21-02-2005, 8:31 AM
#9 (permalink)
| | Member
Thanks: Gave 3, Got 0 |
i went for the carpet option on the walls obviously dark, charcoal grey
no problems at all in fact people say i have managed to give the room a real cinema feel because of it
i didn't use plaster board on my studding i was told that 22mm chipboard would be better so thats what i used i don't think it worked out any dearer than double plaster board but it did mean i only had to board it out once less work and if your paying someone to do it itmay work out cheaper
one of the older pics of the cinema but it does show the carpet,
to stop it looking like the inside of a coffin i split it three quaters the way down on an angle and used a slightly darker carpet closer to the screen which obviosly helps with that contrast |
21-02-2005, 9:07 AM
#10 (permalink)
| | Member
Cool, thanks for the advice gaz - I too was planning on a charcoal grey. I'll speak to my builder about the chipboard situation - may be a good idea - thanks! |
21-02-2005, 10:06 AM
#11 (permalink)
| | Member
Thanks: Gave 8, Got 33 |
Have a look at this thread from the Acoustics treatment section, Acoustic Wall Panels - what fabric to cover?
It contains links to some really great example of wall coverings and they don't have to cost the earth to get good results.
Pemberto
__________________ Denon A1SR, Pioneer 50MXE1, Lumagen ProHDP, Arcam 79, Pioneer LD 919E, (2) Sky+, Sony 777ES Tuner, Pioneer 509 CDR, JVC DVHS, SVHS, (2) Xbox 360 + HD DVD , Xbox, PS2, StraightWire & VDH cables, Crestron Pro 2, STX-1700c, ST-LT Lutron Interface, AppleTV, MS Home Server, Kef THX 7.2, Zektor HDS4.2 |
